plugs and wires?
Old May 5, 2004 | 09:28 PM
SLIMER's Avatar
SLIMER
Cruising
Default plugs and wires?
can anyone tell me what are the best plugs and wires out there.. I have a 1998 c5 and looking to give her some juice??? Thanx :steering:
Old May 6, 2004 | 02:54 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: plugs and wires? (SLIMER)
SLIMER
Your not going to see GOBS of HP by changing your wires. I used AC Delco rapid fires in my 98 and they seem to work well.
I found out that I had two bad wires during the plug change. I measured each wire with an OHM Meter and they all read around 350 ohms except the two bad ones. They were in the 1-2 MEG OHM range :eek: They were still firing alright but would have sooner or later failed. If they were all reading the same (300-500 ohms), I would have probably not replaced them. They failed because of a careless GM mechanic.
I ordered Magnecors and have been happy with them. They are able to use the factory metal shields and seem to be holding up nicely.
Dont go overboard on wires! If you have headers, I would recommend adding some cool socks to keep the wires from getting too hot.
BC
Old May 6, 2004 | 10:22 AM
carpe dm's Avatar
carpe dm
Default Re: plugs and wires? (Bill Curlee)
SLIMER
BC
:thumbs: :iagree:
Old May 6, 2004 | 06:02 PM
blktie8's Avatar
blktie8
http://www.magnecor.com
ngk tr55
Old May 6, 2004 | 08:18 PM
SLIMER's Avatar
SLIMER
Cruising
thanx gents I appreciate the help...... :yesnod:
Old May 6, 2004 | 08:25 PM
SLIMER's Avatar
SLIMER
Cruising
what about setting the gap... i've heard horror stories? :confused:
Old May 7, 2004 | 11:42 AM
Wah's Avatar
Wah
I use Taylor Thundervolt wrapped in heat insulators. Plugs are NGK TR55IX (Iridium). Gap set at 0.075".
To plugs and wires?
