whine at startup
Old May 6, 2004 | 10:31 PM
prt98's Avatar
prt98
Default whine at startup
When I start the car it has a whine in the area of the alternator. It goes away after a few minutes but then comes and goes. anyone have this or know what it is? :confused:
Old May 7, 2004 | 12:30 AM
jrose7004's Avatar
jrose7004
Default Re: whine at startup (prt98)
Every C5 does that! :seeya
Old May 7, 2004 | 01:31 AM
Sebring_C5's Avatar
Sebring_C5
Mine does it. I think it sounds kind of cool. :cool:
Old May 7, 2004 | 02:28 AM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Re: whine at startup (Sebring_C5)
Air Pump! It is located up in the fascia by the left DRL/Turn signal.
[Modified by XmentalPilot, 11:29 PM 5/6/2004]
Old May 7, 2004 | 05:28 AM
xjcharity's Avatar
xjcharity
St. Jude Donor '21
Every C5 does not do that. :nono: My does not.
Old May 7, 2004 | 07:21 AM
ArmyVette's Avatar
ArmyVette
Whine at startup?
Only from my neighbors when I let the pipes roar at 5:30 a.m. when I'm leaving for work!!
:D :D :D
Old May 7, 2004 | 09:06 AM
jrose7004's Avatar
jrose7004
Default Re: whine at startup (jcharity)
Yours would be the first! :seeya
Old May 7, 2004 | 09:09 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
when you first start your car , active handling is warming up... it takes under a minute then you can here that whine stop... this whine does Not change with engine rpm.
Sometimes if your start your car... especially on a cold day.. and make a hard right or left turn before active handling has warmed up...( usually under a minute ) you will get a DIC message " Active handling warm up"
[Modified by Evil-Twin, 9:14 AM 5/7/2004]
IM QUIKR's Avatar
IM QUIKR
Sorta sounds like a bedroom issue from the title. :lolg:
Takes a while to warm up and then quiets down.
Seriously, What about the air idle valve on the intake. The air pump sounds like a muffled hair dryer so that is probably not the cause. Put a stethoscope on the noise (screwdirver also works) and isolate where it is coming from.
[Modified by drcoffee, 8:13 AM 5/7/2004]
Old May 7, 2004 | 10:27 AM
prt98's Avatar
prt98
Default Re: whine at startup (drcoffee)
Thanks for the replies. I'll try the stethicope. I don't have active handling so I can rule that out. :cool:
Old May 7, 2004 | 03:32 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Default Re: whine at startup (XmentalPilot)
:iagree:
Every C5 with an AIR valve makes this noise.. And last I checked, every C5 sold in the U.S. has an AIR valve! It's that assembly that attaches to the drivers-side exhaust manifold, the crap that gets in the way when you try to change spark plugs! :smash: :cheers:
Old May 7, 2004 | 03:34 PM
TGKx's Avatar
TGKx
Default Re: whine at startup (Dan_the_C5_Man)
I had that on mine, supposedly after 2 altenator swaps mine stopped :confused: If it wasnt the altenator they probably accidentally fixed the problem. :lol:
Old May 7, 2004 | 05:39 PM
simplyred02's Avatar
simplyred02
make sure your battery cables are tight at the battery, about 3out of 5 cars I work have loose cables which causes the alternator to work harder making it whine.
Old Sep 28, 2004 | 09:39 AM
TGKx's Avatar
TGKx
I'll agree here. Had the whine, had a few altenators (3? lol) replaced and it finally stopped.
To whine at startup
