Do it yourself solution to column lock
Old May 7, 2004 | 10:52 AM
taaz024's Avatar
taaz024
Default Do it yourself solution to column lock
I recently had to leave my car overnight at pump #7 at my local Mobil. I refused to take it to the dealer after what they told me it would cost, after the toe. I was able to fix the problem and drive off for under $30.00. Car has been great since. I will share it with anyone that is interested, but not in forum. Too detailed, and don't want to confuse people.
[Modified by taaz024, 4:47 PM 5/7/2004]
Old May 7, 2004 | 10:55 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Do it yourself solution to column lock (taaz024)
You read the techtips and pulled the fuse?
What's with all the secrecy? :confused:
Old May 7, 2004 | 11:05 AM
taaz024's Avatar
taaz024
Default Re: Do it yourself solution to column lock (Umrswimr)
Have you ever tried doing that? You will still have a locked wheel and will still get the message asking you to remove the key for 10 seconds. That was the first thing I tried without results.
Old May 7, 2004 | 11:06 AM
carpe dm's Avatar
carpe dm
You rented a Honda..... :rolleyes:
Old May 7, 2004 | 11:16 AM
taaz024's Avatar
taaz024
Default Re: Do it yourself solution to column lock (carpe dm)
LOL, I don't think I can handle driving a Honda after owning a vette!! Basically, I made a temporary wiring harness to reset the column lock assembly. Pulling any of the fuses does not reset it. After getting under way, I talked a friend from Chevy and was told that they usually have to replace the lock assembly
Old May 7, 2004 | 11:29 AM
Mark S.'s Avatar
Mark S.
Tell us more about this temporary wiring harness you're using.
Old May 7, 2004 | 11:38 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: Do it yourself solution to column lock (Mark S.)
:iagree:
why all the secrecy ???
Old May 7, 2004 | 11:42 AM
taaz024's Avatar
taaz024
Basically, I made a harness that I keep in my car at all times now in case I ever have the problem again. I have made a few for others as well to keep with them. It plugs in under the dash panel only for a second and is then removed. E-mail me for more details. I don't want to mislead anyone and cause them electrical problems by not being detailed. I am going to type up a detailed explaination, and can make the harness if you want. It can all be done with basic understanding of auto electronics.
Old May 7, 2004 | 11:58 AM
red97vette's Avatar
red97vette
i''ve got a 97 model, and it hasnt got the bypass...ive never had any problems with it, but when i do (knock on wood...) id like to be able to take it home... can you send me ur explination on how to make this harness? *btw im not too electrically inclined)
thanks!
:cheers:
my email is roed095@hotmail.com
[Modified by red97vette, 4:59 PM 5/7/2004]
Old May 7, 2004 | 12:11 PM
taaz024's Avatar
taaz024
Default Re: Do it yourself solution to column lock (red97vette)
Anyone that doesn't want to get stuck like I did, e-mail me at clark_mc@bellsouth.net.
Old May 7, 2004 | 12:52 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
thanks!
:cheers:
I suggest you buy a known working product from a known vendor then ;) :cheers:
Old May 7, 2004 | 01:35 PM
chuckster's Avatar
chuckster
Basically sounds like step one of installing the column Lock Bypass. Apply a momentary 12v to the lock motor to cause it to retract. Essentially resetting the servo motor. ;)
With the bypass ...it with fools the system into thinking the motor did it's job..
Old May 7, 2004 | 01:39 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Do it yourself solution to column lock (chuckster)
:iagree:
Old May 7, 2004 | 05:45 PM
taaz024's Avatar
taaz024
Default Re: Do it yourself solution to column lock (pewter99)
That is all it is, your right. There is no need to take it to the dealer for that. They replace a bunch of parts for nothing. Like I said, anyone with knowledge in electronics can make a simple harness like I did to reset the motor, and you are on your way. The bypass kit is over $100.00, but there are many people that don't know enough about electronics to do the work. The point is to be able to reset it quick for under 20 bucks if you get stuck. I am not trying to make a big secret issue of it, just help a fellow vette owner save money for gas, not the dealer!!!!! :thumbs:
Old May 7, 2004 | 06:20 PM
chuckster's Avatar
chuckster
You know, for folks who want to keep the Column Lock.. (I have no idea why...)
A great idea would be to wire this circuit in. Then have a little momentary switch button under the dash already wired to the 12v..
If you get a column lock... Push the red button and listen for the ZZZZZZZZT.. Done..
Old May 7, 2004 | 06:29 PM
mmorse's Avatar
mmorse
I had the column lock several times over the years on my '01. I always used the pull hard on the wheel while turning the key to the on position. Worked every time. Never had to leave the car or get it towed. Takes a littlke practice but it never failed. :D
mark
To Do it yourself solution to column lock
