oil pressure?
Old May 7, 2004 | 10:04 PM
414a4coupe's Avatar
414a4coupe
Default oil pressure?
just fired up my 414 and it has 25lbs of oil pressure hot at idle and 40lbs at normal driving.i used a ported zo6 oil pump and 10-30 non synthetic oil.is this normal ?
Old May 7, 2004 | 10:09 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: oil pressure? (414a4coupe)
You are well within the normal range! :cheers:
Old May 7, 2004 | 10:19 PM
414a4coupe's Avatar
414a4coupe
Default Re: oil pressure? (LoneStarFRC)
thanks. this thing sounds nuts. i cant wait to get it tuned and get on it.i need to get rid off my corsa pace cars they are way way to LOUD. :D
Old May 7, 2004 | 10:25 PM
LoneStarFRC
When you say "ported" Z06 oil pump I assume you mean one that has been slightly modified for more oil volume. It's not uncommon for a higher volume pump to have a slightly lower pressure. No biggie. The main thing is that it has plenty of oil volume while still being in an acceptable pressure range. You sound like your in good shape.
Robert
To oil pressure?
