Goal-max hp & tq but driveable on street. No drag or track racing. Mean sounding. Add F1R SC later.
PLAN-427 Darton block- 15 cc dished pistons-Stage III 72cc heads-10.8 to 1 CR-Comp rocker arms, push rods, springs, etc.-double roller chain-42# injectors(too small?)-FAST manifold-90mm TB-Big cam(probably LG G7)-LG long tube 13/4 headers withx pipe and 3" random cats(17/8 Kooks?)-stock Z06 cat back now, 3"in & 31/2" out later-electric water pump-hi cap fuel pump-Be cool radiator & low temp thermo-Blackwing intake-ASP 25% underdrive pulley(will this hurt timing chain?)-Shogun breather canister- Exedy twin disk clutch-upgraded plugs,wires,etc. If add F1R SC later, use stage III 6.01 heads to lower CR to 9.68 to 1, use 75lb injectors, retune.
Any thoughts, ideas, suggestions? Thanks for any help
That will be a nice car when you get it done with a 427 and a SC. Have you thought about droping your CR lower yet? If your going to SC it you can go lower so you can make more power with that SC? I would post this on the Forced Induction area and ask them also what they think. I know that if your going to run a 427 with SC I would go with 1 7/8" headers and 3" full exhaust. I would also ask around more if that cam is the best for SCing. Post pictures of your project.
That's a great selection of parts..... I wouldn't change anything, it should make over 550/550 N/A...if you go to an F1-R, just swap the heads for Stage III 6.0 l heads that are chambered for lower compression, maybe 9.5:1 ... Those are the heads that I'm using and making 800+rwhp. With the 90mm TB and intake, slightly bigger cam and 2 lbs less boost, you should make over 750 rwhp...maybe 800.
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Re: Help with 427 NA plan for Z06 (monstermouse)
Sounds like a PERFECT PLAN. Call MTI they will hook you up, ask for JAYSON the owner, I did and i have a big smile on my face everytime i drive my 427 cid C5R MTI Z07 Motor!!! :cheers: :cool:
