Getting ready to install Sportbrake drilled and slotted rotors on an '03 :thumbs: Never have done it before. Could use some helpful hints before I start. :cheers:
Remove wheel, take two bolts holding brake caliper on rotor off, lift caliper off rotor setup on suspension. You likely have some small keepers (washer looking items) screwed onto studs holding rotor on remove them. At that point the rotor should be free but may be rusted a bit on tap along outside edges with rubber mallet until it is loose the simply pull straight off and reverse the process. Remember if your brake pads are not new or nearly new you may be well advised to get new ones and go with ceramic. any problems email me with Phone and I will call you back. GOOD LUCK
Clean any rust, etc. off the hub so that the new rotor will fit flat against the hub.
Thanks, seems pretty straight forward. Car has 3500 easy (no panic stop) miles. I would guess the pads are still in pretty good shape. I'll probably give it a shot next weekend. :thumbs: How best to support the loose caliper while changing the rotor? :confused:
I use some heavy aluminum wire from Radio Shack leftover from a TV antenna installation. The fronts almost reach the ground, and a 4X4 will hold them up from the bottom if you tie off the top to balance it.
