need some fuel system part numbers ...
Old May 9, 2004 | 02:04 PM
molon labe's Avatar
molon labe
Default need some fuel system part numbers ...
anybody know the part numbers for the following two parts:
1. fuel pump gasket and bolt set
2. in-tank fuel strainer
this is for a 99 corvette.
some parts depts have told me that you have to order the whole pump assembly, and others have told me that you can get these parts separately. i already have an aftermarket pump to install, but need these parts to complete the install. :)
thanks,
kw
Old May 9, 2004 | 02:20 PM
Patches's Avatar
Patches
Default Re: need some fuel system part numbers ... (tattooed)
As you can see in the clip I pulled out of the parts manual, they appear to be part of the assembly, as you were told.
Click on image to enlarge
Old May 9, 2004 | 03:00 PM
molon labe's Avatar
molon labe
Default Re: need some fuel system part numbers ... (Patches)
thanks for the info, patches. my main GM parts guy said he can order them separately, so i guess we will see.
Old May 9, 2004 | 03:01 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Dont know the #'s but you can get the bolt kit and seal package seperately.About $60 :smash:
The left in tank strainer has been updated,so you dont want the old part #.The old design gets soggy and can flop around and get caught on the float arm causing gauge issues.If you have access to the fuel gauge TSB for the 1997-2000,the new strainer part # is listed.
If you send me an e-mail.I can get you the part#'s monday :cheers:
Old May 9, 2004 | 03:40 PM
molon labe's Avatar
molon labe
Default Re: need some fuel system part numbers ... (C-5 TECH)
man, i love this guy! you rule! i'll drop you an email. thanks!!!! :cheers:
Old May 10, 2004 | 06:46 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The part# for the 1997-99 left strainer kit is 12458245 and should come with the seal/bolt kit.I say that because I have the seal/bolt kit in my hand and it has the same part# on it. :) If it does not,let me know and you can have it :cheers:
Old May 10, 2004 | 11:31 PM
molon labe's Avatar
molon labe
you rule! thanks man. :) :cheers:
Old May 11, 2004 | 07:41 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
:cheers:
To need some fuel system part numbers ...
