[LOW OIL]How much when................
Old May 12, 2004 | 05:33 PM
Ben01C5's Avatar
Ben01C5
Default Re: [LOW OIL]How much when................ (Buckmaster)
I wanted to get mine reringed, but I didn't trust any of the dealers here, and then I was outta warranty. :mad
I learned to live with the LOW OIL LEVEL message.
Old May 12, 2004 | 07:00 PM
Oldvetter's Avatar
Oldvetter
I checked mine when changing oil (while filling it up), warning comes on when 1 quart low.
Old May 12, 2004 | 07:07 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: [LOW OIL]How much when................ (Oldvetter)
Mine seems to come on at even less than 1qt low.
Last time I changed the oil, I only had 6qts left in the garage...so since the car's supposed to take 6.5, I added the 6qts I had, and went to get more the following day. I got the "low oil level" message then, and was (what I thought) only missing a half qt. I just added the full qt since I got that message, as I always thought it came on at 1qt low. :confused:
:cheers:
[Modified by Y2Kvert4me, 6:08 PM 5/12/2004]
Old May 12, 2004 | 07:54 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
:lol: Damn.....so between 2 quarts and 1/2 quart :lol: :leaving:
Old May 13, 2004 | 11:31 AM
shockwave's Avatar
shockwave
Default Re: [LOW OIL]How much when................ (John Nowak PE)
Ours comes on at about 1 quart low. Always has. Unfortunately I got used to the message until the car was re-ringed.
:yesnod: Same here. Mine will give me the warning at 1 quart low. My Avalanche does the same thing. On the C5, it happened to me on the road and I only had a 1/2 of quart of Mobil 1 on hand. I added that and a few cycles later the warning light no longer returned.
Old May 13, 2004 | 12:07 PM
Avanti's Avatar
Avanti
My '01 came on at 1/2 quart low! Go figure!
It was at the Shivvy dealer for something else and they called and told me the light came on (instead of putting in a quart and charging me $10 :lol: ). I poured in a half quart, drove home, light never came on in the 3 miles, let her set, checked it--spot on! :confused:
Who knows? Oil sensor's apparently no more accurate than either of my sets of tire pressure sensors. :lol:
All the best. :yesnod:
