Active Handling Warming Up??????
Old May 11, 2004 | 11:18 AM
jimk's Avatar
jimk
Default Active Handling Warming Up??????
Yesterday PM I go and jump into my car, start it up and start getting a chime and the DIC states "Active Handling Warming Up". This is the first time I have ever seen this happen and the car was 100 degrees + from sitting out in the sun here in NC. Is this just a prelude to a bigger problem?
Old May 11, 2004 | 11:25 AM
CDH76's Avatar
CDH76
Default Re: Active Handling Warming Up?????? (jimk)
no, it happens from time to time. I cannot remember the reason for it but you should be fine. :thumbs:
Old May 11, 2004 | 11:48 AM
vettenuts's Avatar
vettenuts
Default Re: Active Handling Warming Up?????? (Chad954RR)
Were you driving slow when it happened? I think there is a write-up in the owner's manual on this. If I remember correctly, in order for the system to initialize, it needs to be over a certain speed. If you drive slowly on first start, you will get this warning. I get it a lot since I am no a dead end street and drive slowly up the road before coming to a main road. It is not a problem, don't worry about it.
[Modified by vettenuts, 6:19 AM 5/13/2004]
Old May 11, 2004 | 12:10 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Active Handling Warming Up?????? (vettenuts)
Happens here in AZ, but only when its over 100 outside.. wierd... cause its already HOT outside.
Old May 11, 2004 | 07:17 PM
Velocity Driven's Avatar
Velocity Driven
Were you driving slow when it happened? I think there is a write-up in the owner's manual on this. If I remember correctly, in order for the system to initialize, it needs to be over a certain speed. If you drive slowly on first start, you will get this warning. I get it a low since I am no a dead end street and drive slowly up the road before coming to a main road. It is not a problem, don't worry about it.
That might hold true........the one time it happened to me was in first gear at a near crawl. Never re-occured again. Hmmmm, I hope your right.
Respecfully,
Velocity Driven
Old May 11, 2004 | 07:40 PM
dpd's Avatar
dpd
this happens because the brake control unit didn't see enough steering angle left and right and road speed was less than 6 mph[i believe].after all these parameters are met,you should get warm up complete.
Old May 12, 2004 | 08:37 AM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
It has nothing to do with the temperature. For the active handling system to calibrate itself, it needs for you to drive in a relatively straight line. If you start up, do a U turn around the back of a gas station, and turn onto a curving road, you might see this.
Old May 12, 2004 | 04:52 PM
allanlaw's Avatar
allanlaw
It's perfectly normal - as it says, it's just a "warm-up" thing, not a fault code.
Old May 12, 2004 | 04:58 PM
Avanti's Avatar
Avanti
Happens on my '01 about every 5 or 6 months. But, immediately says it's warm and ready (wish everything was that quick).
No big deal.
All the best. :yesnod:
Old May 12, 2004 | 09:03 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Default Re: Active Handling Warming Up?????? (allanlaw)
try the air intake temp sensor on the air bridge. The wires will come lose and it will stop reading, and eventually set a code. IF the sensor is not hooked up, or is not reading it will set of the active handling warming up. If the sensor isn't working, it will defauld to -37deg and the car will think it is soo cold that the active handling has to warm up. Happened to me twice, and i have seen it on numerous other vettes
Let us know the outcome :cheers:
Old May 13, 2004 | 06:23 AM
vettenuts's Avatar
vettenuts
Default Re: Active Handling Warming Up?????? (Mr. Big)
I don't believe that the intake sensor has any function in the active handling system. There are a set of parameters the active handling system needs to initialize and if driven in a certain manner you will get this warning until such time as the car is driven such that the system can initialize. I believe there is a write-up on this in the owners manual, although it was a awhile ago when I read it so it might be the service manual.
Old May 13, 2004 | 08:17 PM
Mr. Big's Avatar
Mr. Big
nope, it has eveything to do with it. if you unplug it and start the car, you will not get a ses light, but your active handling warming up will come on. I had that exact problem, i thought my AH was messing up. I called Joseph up at TSP and he told me to check that sensor, sure enough the wires had come lose and it was reading -37 deg I fixed the sensor and immediatly fixed the problem. So i know they are related :cheers:
Old May 14, 2004 | 06:09 AM
vettenuts's Avatar
vettenuts
Interesting, didn't believe the two were related.
Old May 14, 2004 | 10:49 AM
Mike Mercury's Avatar
Mike Mercury
ding... ding... ding; we have a winner !
It has nothing to do with the temperature; and is a poor choice of words by GM. If they would of used "Active Handling Calibration Routine" - or something similar - we wouldn't all be so confused. :crazy:
To Active Handling Warming Up??????
