Got a problem, need your help
Old May 13, 2004 | 12:04 AM
SilverStar's Avatar
SilverStar
Default Got a problem, need your help
For a couple of weeks I have been finding a drop or two of oil on the garage floor near the rear end and have been ignoring it. The drops are getting worse and I am worried.
Jacked the car up tonight for a peek. It appears to be coming from the rear end, in front of the cross member which has a coating of oil as does the spring.
Here is the funny part. There are two distinct spots. The one to the right of center is pink like ATF fluid (yes it is an A4). The one to the left of cneter is brown like heavy oil (rear end?).
I have been experiencing tranny slippage on the 4-3 downshift for about a month. I have an FLP level 4 with a blower and I just found out no vacumn check valve. Could the trans be leaking at the rear in the carrier. I only to need get to L.A. (400 miles) next week where Andy will be installing a level 5.
If it is the rear end I need to deal with it immediately. I don't want to fry my 3.73s. Here's another question. The bottom of the rear carrier, in about the center, between some heat sink fins has a hole. It appears solid up in the hole, not like a missing drain plug (which would be leaving a lot more than a drop). Is it a drain plug?
As you can tell, I am not mechanical. What do you think.
Thanks in advance for your replies.
[Modified by SilverStar, 11:07 PM 5/12/2004]
[Modified by SilverStar, 11:10 PM 5/12/2004]
Old May 13, 2004 | 12:48 AM
SilverStar's Avatar
SilverStar
Default Re: Got a problem, need your help (SilverStar)
ttt
Old May 13, 2004 | 02:41 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Sounds like that dreaded seal problem. When I changed TQ Converter and gears I developed a leak. Took it back to WCC and they had to drop the tranny to replace the seal under warranty.
Old May 13, 2004 | 04:47 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have to go with the seal problem :yesnod:
To Got a problem, need your help
