99 m6
Old May 13, 2004 | 10:44 AM
jjgree's Avatar
jjgree
Default 99 m6 H/C swap
I'm planning a c/h swap and have been looking into MTI stage 2 heads and stealth cam. I will use a ZO6 exhaust. Does anyone have experience with MTI and what kind of RWHP should I expect?.
JJG :cool:
[Modified by jjgree, 3:58 PM 5/13/2004]
[Modified by jjgree, 4:05 PM 5/13/2004]
Old May 13, 2004 | 11:19 AM
HITMAN99's Avatar
HITMAN99
Default Re: 99 m6 H/C swap (jjgree)
The Stealth 1 cam is a 220/220 115 LSA w/ .580 or so lift. IMHO, this lift is a little on the high side for a 'Stealth" cam, as you will probably get a bit of valvetrain noise. WIth a good set of headers and other bolt-ons, I have seen similar cams pull over 400 RWHP.
The Stealth 2 cam has a bit more duration (224/220), wider LSA (116), and a slightly lower lift. Because of the reverse split, I would only run this cam w/ a good set of LT headers.
Both cams would do very well w/ a more mild set of heads, w/ stock-sized valves.
