Bleeding/Flushing Clutch fluid
Old May 13, 2004 | 01:39 PM
Falcon's Avatar
Falcon
Default Bleeding/Flushing Clutch fluid
Anyone have the directions from the C5 service manual they'd share with us for performing this procedure on a C5?
TIA!
Old May 13, 2004 | 03:12 PM
luvinc5's Avatar
luvinc5
Default Re: Bleeding/Flushing Clutch fluid (Falcon)
If you follow the service manual directions, you'll be cursing all day long. It involves disconnecting the exhaust pipes, removing the torque tube tunnel cover plate and accessing the bleeder screw near the top side of the clutch housing.
What I did was alot easier. Remove the old brake fluid in the clutch master cylinder and replace with new for about 4-6 cycles (let 2-3 days pass between cycles) and you will have achieved the same results with alot less pain.
Old May 13, 2004 | 07:04 PM
69's Avatar
69
Cruise-In VI Veteran
Here ya go....
http://97vette.com/howto/clutchbleed/index.html
Old May 13, 2004 | 07:29 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Bleeding/Flushing Clutch fluid (luvinc5)
I am in the middle of this process :lol:
Old May 13, 2004 | 07:51 PM
vettenuts's Avatar
vettenuts
Default Re: Bleeding/Flushing Clutch fluid (pewter99)
I don't think replacing the fluid in the master cylinder will ever get to the slave cylinder, there is not circular route to flush the fluid. The only way to do it is to open the slave, and this involves dropping the cover plate.
Old May 13, 2004 | 09:57 PM
luvinc5's Avatar
luvinc5
Default Re: Bleeding/Flushing Clutch fluid (vettenuts)
Changing the fluid thru the master cylinder isn't the best way but it does seem to work from my experience.
Old May 13, 2004 | 10:20 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
I do mine in about 3 minutes :D
To Bleeding/Flushing Clutch fluid
