Convertible Roll Bars
Old May 14, 2004 | 02:18 PM
mgora1's Avatar
mgora1
Default Convertible Roll Bars
1)Anybody have any pics of a roll bar installed in a Vert? Can you alo comment on any pros/cons of having it installed.
2) Will the roll hoops pass for track days?
Old May 14, 2004 | 02:58 PM
blackbelt's Avatar
blackbelt
Default Re: Convertible Roll Bars (mgora1)
im in the same boat as you. Roll hopes will not pass for track days :nonod: . Check out mean greens cage it is a piece of art and i believe east coast did it. I will be getting the same one hopefully.
Old May 14, 2004 | 03:17 PM
The One's Avatar
The One
Default Re: Convertible Roll Bars (blackbelt)
...Check out mean greens cage it is a piece of art and i believe east coast did it.
:iagree: That is a nice bar. :yesnod:
Here's mine. :)
Old May 14, 2004 | 03:26 PM
Y2K Z07 MAN's Avatar
Y2K Z07 MAN
Default Re: Convertible Roll Bars (The One)
Joe (The One)
You have a nice 1 also!!!!
Where did you tell me it is from?
I can't make it to the E.C. for the install
David
Old May 14, 2004 | 03:40 PM
The One's Avatar
The One
Default Re: Convertible Roll Bars (Y2K Z07 MAN)
Thanks David. Contact Brian at Real Performance Motorsports - (972) 434-2151. I think they're closed today and tomorrow for an event, but try him from Monday on.
:cheers:
Old May 14, 2004 | 03:43 PM
NPh2005's Avatar
NPh2005
I've also considered a roll bar too. Actually IM'd Mean Green about his and if I get more serious about it I would talk to him about his. I know Wolfcraft makes some. Heres a web site. http://www.wolferacecraft.com/default.aspx
Looks however is also one of my concerns. Good luck. :seeya
Old May 14, 2004 | 03:44 PM
powderski13's Avatar
powderski13
The One (Joe):
Great looking set-up. Who did the work? Does the top still work without interference from the roll bar? Are the cross bars removable? How much was it?
Old May 14, 2004 | 03:56 PM
mgora1's Avatar
mgora1
...Check out mean greens cage it is a piece of art and i believe east coast did it. :iagree: That is a nice bar. :yesnod:
Here's mine. :)
Hey Joe. That is slick. Appearance is key to me as others have mentioned as well. Where did you get your made/installed?
Old May 14, 2004 | 04:14 PM
The One's Avatar
The One
Thanks guys. The top is operational and the door and center bars are removable. Actually, so is the hoop (refer to the pics. :) ) The hoop's never in the way, however, so I typically just remove the door/center bars - 2 bolts each/3 minutes of work total. The bar can be powdercoated to your liking. I tend to like the stealth approach, so I went with black. :D
With the door bars out, the interior looks stock. There's no bulky plate on the floor because the bar bolts to the side. The only negative thing is that the tonneau does have to be notched, but you can see by the pics how clean a job they do. The only way to avoid this is to mount the main hoop further forward in the cab, which limits seat travel. I have full seat movement and I don't have my noggin an inch from the main hoop. :eek:
Fabrication and installation was done by a well-known NHRA dragster chassis builder. Real Performance Motorsports in Lewisville, TX can hook you up. :yesnod:
:cheers:
Old May 14, 2004 | 06:11 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Thanks "The One" :D
Old May 14, 2004 | 10:00 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Check the sig... The guy is not building any more of these... sorry!!
VR :cheers:
Old May 18, 2004 | 07:51 PM
mgora1's Avatar
mgora1
Default Re: Convertible Roll Bars (Mean Green)
Thanks "The One" :D
Hey Mean Green. Thanks for the Vert Roll bar pics. That is a great looking set up. Where did you get that and can you send me the contact info for the shop? Also, what are the cons to the roll bar if any? Thanks
Old May 18, 2004 | 09:33 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Thanks for putting up the pictures Mark. Feel free to call me at the shop. We do all our own custom cages in house.
609-752-0321
:seeya :seeya
Old May 19, 2004 | 01:28 AM
James G's Avatar
James G
Default Re: Convertible Roll Bars (CHRIS NJ C5)
I would not want to be in ANY kind of side impact with that bar. It'll bust yer head open like a mellon. Why is it so far forward ?
Old May 19, 2004 | 09:24 AM
Cruise-In V Veteran
Default Re: Convertible Roll Bars (James G)
Thats as far back as it ccan go and still have the top function. You can pad the side bars if you want. I did that on my car. :seeya
Old May 19, 2004 | 08:14 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
609-752-0321
:seeya :seeya
:D
He caught up with me via IM and should have contacted y'all already :D :cheers:
Old May 19, 2004 | 08:28 PM
kh24's Avatar
kh24
Every rollbar that anyone maks for a vert is just like that. Padding it is all you can do.
To Convertible Roll Bars
Old May 19, 2004 | 11:02 PM
James G's Avatar
James G
Default Re: Convertible Roll Bars (kh24)
Not entirely true, the wolf bar sits well behind the seat of the coupe. I'm 5'10 and the wolf bar is a good 5''+ behind me so I suppose if are tall you and have the seat max'd that would be another thing. Also, the angle at which the bar is canted is a factor. I can see how a coupe bar could afford more angle than the convertible bar. I'm working on a project to use a wolf bar and make it an SCCA legal double hoop. Check out the picture and tell me what you think. :seeya
http://www.cardomain.com/memberpage/578587/3
[Modified by James G, 4:03 AM 5/20/2004]
Old May 20, 2004 | 12:17 AM
kh24's Avatar
kh24
My wolfe bar in my z06 is also behind the seat but I have installed them in verts before and its different. If you want the top to still function thats how its gonna be. Im sure if there was another way they would have done it because the probably is quite obvious but thats the only way to keep the top working.
Old May 20, 2004 | 12:56 AM
blu00rdstr's Avatar
blu00rdstr
Somebody made/makes a setback rollbar that can rock forward to drop the top when it's in street mode. It was NHRA approved. I don't remember who it was from.
