Any idea why I keep getting P0300?
Old May 14, 2004 | 09:09 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Any idea why I keep getting P0300?
This code pops up every few days or so. It has been that way since I got my heads/cam. Any ideas on how I can fix this or what to check? I know its a misfire code but don't know where to start on fixing the problem. Thanks, Kaley
Old May 14, 2004 | 09:13 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Any idea why I keep getting P0300? (2C5only21)
It is usually removed on cam or head and cam installs. Most larger cams will set this code. Just have it removed by who ever did your tuning.
Old May 14, 2004 | 10:01 PM
Kenny94945's Avatar
Kenny94945
P0300 engine misfire detected.
Cam shaft sensor is one cause.
Also vaccuum hose leaks, throttle body and intake manifold leaks, crankcase ventilation valve, fuel injector harness, low fuel pressure/ dirty fuel filter, spark plug or coil pack. Lots of stuff to test...you'll need a manual.
Old May 14, 2004 | 10:31 PM
HalfMoon's Avatar
HalfMoon
Default Re: Any idea why I keep getting P0300? (CHRIS NJ C5)
:iagree:
It's the cam. Have the code turned off with LS1Edit / HPTuners...
Old May 15, 2004 | 12:46 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Any idea why I keep getting P0300? (Tony_C5_04)
On the simple side,,,make sure that your coil packs wires and plugs are not damaged and the engine is not really missfiring.
BC
Old May 15, 2004 | 07:25 AM
dpd's Avatar
dpd
it's due to the cam.
To Any idea why I keep getting P0300?
