Blackwing install issue
Old May 15, 2004 | 07:48 PM
Mike52's Avatar
Mike52
Default Blackwing install issue
I just finished installing my Blackwing on my '98 but I cant seem to get it fitted correctly. I think I got all the connections on like I should but I cant seem to get the grommets on the radiator shroud to line up with the air bridge. Ill post some pictures, maybe you guys can tell me if I did something wrong.
Oh, and while installing the filter I managed to drop the one part that it says specifically not to drop, directly into the motor. :banghead: Luckily, I eventually found it but it took some doing to get it out.
[Modified by Mike52, 7:51 PM 5/15/2004]
Old May 15, 2004 | 07:52 PM
Mike52's Avatar
Mike52
Default Re: Blackwing install issue (Mike52)
Here's a shot of the MAF assembly, dont know if I did something wrong here or not.
http://www.boomspeed.com/eviloatmeal/Mike/MAF.jpg
[Modified by Mike52, 7:52 PM 5/15/2004]
Old May 15, 2004 | 07:55 PM
jmzvet's Avatar
jmzvet
Mine doesn't sit down either and niether do about 50% of the ones out there. Don't sweat it. It's not going anywhere.
Old May 15, 2004 | 08:28 PM
Mike52's Avatar
Mike52
Default Re: Blackwing install issue (jmzvet)
Oh, I tried to move the whole thing with my hands and noticed it wouldnt move much. I just wanted to make sure it wasnt something I did, odd how it fits differently on different cars. :confused:
Old May 16, 2004 | 12:40 AM
Blown2K's Avatar
Blown2K
The Blackwing on my '04 fits exactly how your photos show. I was breaking a mean sweat trying to make it fit perfect and even took it off and put it back on about 4 times. I gave up since it feels firm anyways. It won't fall off and I've had it this way for about 800 miles, no problems.
Old May 16, 2004 | 12:43 AM
Nomar's Avatar
Nomar
Mine fit pretty much the same way, works great haven't had any problems.
Old May 16, 2004 | 08:44 AM
AFVETTE's Avatar
AFVETTE
Many have this fit issue. I got lucky and mine fits flush, but I have seen some that don't even make contact with the posts and actually touch the hood liner when the hood is closed.
I would have thought by now Donaldson would have fixed this.
Tom
Old May 16, 2004 | 05:25 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
I don't use the grommets...............
Old May 16, 2004 | 06:46 PM
TXSTICK's Avatar
TXSTICK
Make sure all clamps are loose, adjust and then tighten them.
Old May 16, 2004 | 09:59 PM
kenrobb's Avatar
kenrobb
Default Re: Blackwing install issue (TXSTICK)
I put one on my son's 99 and on my 03 and both fit flush. Agree with above post, lossen everything and adjust. They should fit correctly.
Old May 16, 2004 | 10:09 PM
Geoff McD's Avatar
Geoff McD
Default Re: Blackwing install issue (kenrobb)
I have had the RK Sport twin flow for about 3 years now....haven't used the gromets (mine didn't exactly work either). Not an issue at all for me! :thumbs:
Old May 16, 2004 | 10:53 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Default Re: Blackwing install issue (Geoff McD)
When I had my RM twin flow...sat flush here. I have changed my air bridge, it doesn't come close at all now :D
[Modified by Scratch, 8:53 PM 5/16/2004]
Old May 17, 2004 | 12:31 AM
zguy's Avatar
zguy
:iagree:
Had the same problem. Loosen all the clamps while being installed and align accordingly.
:cheers:
Old May 17, 2004 | 07:03 PM
Lancer033's Avatar
Lancer033
mine has been on for about 15k miles and looks just like yours. Don't worry about it, it ain't going anywhere
To Blackwing install issue
