Jacking Position
Old May 16, 2004 | 02:29 PM
TomsZ06's Avatar
TomsZ06
Default Jacking Position
I drove my car up onto some ramps but needed to also jack up the front end to get more working clearance underneath. I used a piece of 2 by 8 under my jacking wedge but wanted to know what front crossmember should I have used because there was one that the front suspension was mounted to and then there was one directly behind it. Which is the correct one?
Old May 16, 2004 | 02:58 PM
Ranger's Avatar
Ranger
Default Re: Jacking Position (TomsZ06)
I emailed you a jpg of the jackpoints diagram from the service manual. Should be there now.
Ranger
Old May 16, 2004 | 03:02 PM
allanlaw's Avatar
allanlaw
For center jacking use rear crossmember. For jack stands on either side, either front or rear crossmember is ok - this is per service manual ('01)
Old May 17, 2004 | 06:51 PM
TomsZ06's Avatar
TomsZ06
Default Re: Jacking Position (Ranger)
Thanks Ranger.
To Jacking Position
