Everyone With Headers
Old May 16, 2004 | 04:39 PM
TomsZ06's Avatar
TomsZ06
Default Everyone With Headers
Is it wise to place some type of heatwrap between the headers and the starter? Is there anything esle that should be done besides keeping the O2 semsor wiring away from the headers?
Old May 16, 2004 | 05:02 PM
AFVETTE's Avatar
AFVETTE
Default Re: Everyone With Headers (TomsZ06)
If your headers are jet coated there shouldn't be any need.
Tom
Old May 16, 2004 | 05:24 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
I haven't and have had no issues. I did however buy some "Koolsox" and put them on the wires as insurance..................
Old May 16, 2004 | 06:11 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Everyone With Headers (AFVETTE)
:iagree:
VR :cheers:
Old May 16, 2004 | 06:13 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Everyone With Headers (vetterdstr)
And if they aren't jet coated?
Old May 16, 2004 | 06:32 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Everyone With Headers (barkingowl)
I cooked 2 starters in 6 months with the arizona heat. I added heat wrap on the header to keep the heat away from the starter and o2 wiring.
Old May 16, 2004 | 08:29 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Hm... I need to get mine up in the air and chcek the clearances... I haven't had any problems yet. The other day the car took a hair longer to start, but I dunno...
Old May 17, 2004 | 08:18 AM
RyanC7's Avatar
RyanC7
Default Re: Everyone With Headers (Cobra4B)
I have no issues with heat with my SW headers.
Old May 17, 2004 | 09:12 AM
wrustywrench's Avatar
wrustywrench
I have found that even with coating, you still can cook starters, this happened on a street rod with 1/2 air gap between the tubes and starter. So rather than find out on the vette,,I got some heat reflective blanket material and seeing it was next to impossible to actually wrap the starter, I wire tyed it to the positive cable above the starter and draped it between the headers and oil pan, the tyed it to the transmission oil line. It works great, protects the wires, starter and does not pose a problem ,,I also used heat shied tube and covers the o2 sensor wires....better safe than sorry....I have LG headers. I even applied reflective material to the trans tunnel and transmission pan sides.
[Modified by wrustywrench, 2:14 PM 5/17/2004]
Old May 17, 2004 | 10:48 AM
vetterdstr's Avatar
vetterdstr
I think it has more to do with your climate than anything else... I have ran my car at the race track in 108 deg weather all day for 2 days.. that torture tested the heck out of my car. Ihad no problems with wires, or a starter before, during or after that time. I can see how the Arizona heat would make a diff.
VR :cheers:
Old May 17, 2004 | 01:35 PM
chimneyguy's Avatar
chimneyguy
I started getting the spongy clutch pedal problem, I think the headers were the cause, bleeded the fluid and wrapped part of them and bled the fluid as best i could, so far no more problems. Bottom line it deffinitly cant hurt.
Old May 17, 2004 | 01:53 PM
Face's Avatar
Face
Default Re: Everyone With Headers (Buckmaster)
I had to install some after my old TPIS headers cooked some wires.
Old May 17, 2004 | 03:28 PM
wwashing's Avatar
wwashing
Default Re: Everyone With Headers (ICULUKN-C5)
I wouldn't do this any place except maybe Az. Long term wrapping of un-coated hearders can lead to corrosion issues on the headers, perhaps just ugly looks if they are SS. Perhaps it's dry enough in Az for this to not be an issue? :cheers:
Old May 18, 2004 | 04:12 PM
FKING1's Avatar
FKING1
Default Re: Everyone With Headers (wwashing)
Watch your plug wires. I burned a couple before putting on a set of MSD's the correct length. Had cool socks but didn't like them.
Fred K.
:iagree:
To Everyone With Headers
