Leaky rear end?
Old May 16, 2004 | 06:15 PM
666 Z06's Avatar
666 Z06
Default Leaky rear end?
Driving my '03 Z06, I can smell rear-end fluid just after hard acceleration. Also, there's gunk caked on the rear subframe just under the case, and some fluid on the case itself. There's only 4800 miles on the car, most of those on the track. Anything I should check?
Old May 16, 2004 | 06:22 PM
hightest's Avatar
hightest
Default Re: Leaky rear end? (Gradenko)
There has been issues with some of the newer C5's from the halfshaft seals.
There is currently an updated seal for both left and right sides. The updated seals are adouble lip design versus a single lip that is on the old seals.
It's quite possible that this is your problem, and if you're car is still under warranty, the seal replcement is covered by it.
The new GM part number is 88996703 for both sides. :thumbs:
Old May 17, 2004 | 03:21 AM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: Leaky rear end? (hightest)
"Leaky rear end?" maybe too much fiber :jester
seriously, it is a common problem. See you dealer for warrenty repair :cheers:
Old May 17, 2004 | 11:09 AM
sasunlover's Avatar
sasunlover
Discovered mine was doing this the last time it was in for an oil change at the dealer. Te Vet mechanic came over to look at it. He just tightened all the bolts around the seal and this seems to have solved the problem. The all turned at least a quarter turn. Might be worth a try.
Old May 17, 2004 | 05:55 PM
carpe dm's Avatar
carpe dm
C5 diffs will blow a little fluid out a vent, if you use the right pedal too hard. Clean it up and see if it come back under normal driving. Many "leaks" are just a little blow-by. You can also try changing your fluid and adding the correct amount, not over-filling, as some seem to come from BG. :yesnod: :)
Old May 17, 2004 | 07:35 PM
blackjack's Avatar
blackjack
Probably over filled. Many are...
To Leaky rear end?
