fuel gauge malfunction
Old May 16, 2004 | 10:15 PM
2000droptop's Avatar
2000droptop
St. Jude Donor '07
Default fuel gauge malfunction
Hey,
I'm crusin along with 1/2 a tank o fuel then outa the blue I got none........
Or so the DIC and fuel gauge says.
About 30 min later the gauge comes back?????? :confused:
Old May 17, 2004 | 01:20 AM
Tom337's Avatar
Tom337
Default Re: fuel gauge malfunction (2000droptop)
Try Running a fuel additive called Techron,Sold at Wallmart, It worked for me. :yesnod:
Old May 17, 2004 | 08:08 AM
Als98C5's Avatar
Als98C5
I dealt with that problem for about a year before I finnally got around to fixing it. $1200 later and a some new gas tank sending units, it's fixed.
Old May 17, 2004 | 08:22 AM
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: fuel gauge malfunction (Als98C5)
I have been dealing with this for almost a year. At first I could swerve the car at low speed, as if I was cleaning the tires and the gage would start functioning again. Now I live with it until I get to a place to stop. Turn the engine off wait a few seconds and restart. It resets it's self and is good to go.Mine only occurrs at 2/3 's full or more. Leading me to believe it is a sensor for the top of the right side tank?? As prevelant as this has become, why hasn't GM had a recall???? :nonod:
Old May 17, 2004 | 08:24 AM
Sixgun95's Avatar
Sixgun95
Default Re: fuel gauge malfunction (Tom337)
What will the Techron do?
Old May 17, 2004 | 08:27 AM
jojog's Avatar
jojog
Clear your codes - even on the fly, use BG44K and/or Techron fuel additive, Chevron gas, get PCM reflashed with GM fix for gauge, don't refill with more than 1/4 tank to encourage sloshing/scrubbing action of the fuel, reset the trip odometer each time you refuel - good luck! :thumbs:
To fuel gauge malfunction
