Grease fitting locations
Old May 17, 2004 | 06:50 PM
georgehafe's Avatar
georgehafe
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
Default Grease fitting locations
Can someone let me know how many and where are all the grease fittings on an 02. Just want to make sure I don't miss any when I do the lube.
Thanks :flag
Old May 17, 2004 | 06:54 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Grease fitting locations (georgehafe)
There are 0 grease fittings on a C5...which makes them very tough to find. :D
:cheers:
Old May 17, 2004 | 07:06 PM
YELLOHHH's Avatar
YELLOHHH
:skep: :leaving:
Old May 17, 2004 | 07:22 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
the "007" grease spraying option (used only when the bad guys or cops are chasing you) could be installed in the rear of the car with minimal effort. ;)
VR :cheers: :jester
Old May 17, 2004 | 09:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The Grease fittings are on the box for the double pepperoni Pizza.
Old May 17, 2004 | 09:46 PM
ArmyVette's Avatar
ArmyVette
Default Re: Grease fitting locations (Y2Kvert4me)
:cheers:
Which also means if you get your oil changed anywhere and they try to charge you for lubing your car, you can SMOKE EM! :smash: :smash: :smash:
Had the freakin' CHEVY dealer try to do this to me! Tried to charge me an extra $15 for "lube service." :mad :mad :mad
Old May 17, 2004 | 09:50 PM
georgehafe's Avatar
georgehafe
NCM Ambassador
So when I do the oil change thats all I have to worry about? Great :yesnod:
But could someone explain why it's like this. I have an 03 suburban and still have too.
Old May 17, 2004 | 10:10 PM
BHP's Avatar
BHP
Grease fittings went out with carburetors...
Old May 18, 2004 | 11:25 AM
carpe dm's Avatar
carpe dm
No grease fittings on Vettes since '82. :D :hurray:
Old May 18, 2004 | 12:07 PM
Avanti's Avatar
Avanti
Hey, George...
What WAS the last car ya lubed? :lol:
Unfortunately, all wear points sometimes are not as well "sealed & permanently lubed" as manufacturers might like us to believe. Chrysler, for example, has recently had a rash of suspension failures for this very reason, or so it seems.
Personally, I've always liked lubing my own... All the best. :yesnod:
Old May 18, 2004 | 12:50 PM
georgehafe's Avatar
georgehafe
NCM Ambassador
Default Re: Grease fitting locations (carpe dm)
Well I know thats not true as I lubed my '87upper/lower control arm / steering linkage/tie rod.
Old May 18, 2004 | 12:55 PM
LANZ06's Avatar
LANZ06
There are not grease fittings on most cars anymore so that the parts will wear out faster and need replacement. Job security.
To Grease fitting locations
