DTC P0420
Old May 18, 2004 | 09:09 AM
Horseshoe Dozer's Avatar
Horseshoe Dozer
Default DTC P0420
I am getting DTC P0420 (TWC system low efficiency bank 1-A). I recently installed hi-flow cats. Can anyone tell me which side of the car is bank 1-A? Is it the cats or is it possibly the O2 sensors on that side?
Old May 18, 2004 | 11:26 AM
mwittkopf's Avatar
mwittkopf
Default Re: DTC P0420 (Horseshoe Dozer)
I have seen numerous 02+ cars throw the code with hi-flow cats. It seems that the computer is more sensitive to the cats on the newer models. It is most likely nothing to worry about (unless you fail emissions!). Bank 1 is driver side.
Old May 18, 2004 | 11:56 AM
Horseshoe Dozer
Default Re: DTC P0420 (mike@xtreme)
Mike.......Thanks. I'm going to reset the codes and swap the O2 sensors tonight. If the code follows the sensor, then I will know its the sensor. If not, its the cat.
To DTC P0420
