A4 Shift Points
Old May 18, 2004 | 02:41 PM
GrayGlenn's Avatar
GrayGlenn
Cruising
Default A4 Shift Points
I've noticed if I get on the gas lightly the car shifts around 2000 rpm, if I get on it a little more it shifts around 3500 rpm. My question is can the shift points be programmed to a higher rpm and how is it done. Right now I drive around the city in 3rd so it will stay out of 4th.
Old May 18, 2004 | 02:58 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Default Re: A4 Shift Points (GrayGlenn)
There are several tables in the PCM that determine when your A4 shifts in regard to your current MPH and thottle position angle. At WOT shifting at RPM is also a factor.
These settings can be tweaked if you have the right software.
Old May 18, 2004 | 02:59 PM
Mike Mercury's Avatar
Mike Mercury
most of the handheld programers will allow shift point changes only during WOT.
I don't know for certain, but maybe LS1Edit will allow the changes you describe.
Old May 18, 2004 | 03:54 PM
IMQUIK's Avatar
IMQUIK
Default Re: A4 Shift Points (bgood)
:iagree: He knows hiz shiat! :D He is the reason mine shifts so sweet with LS1 Edit.
Old May 18, 2004 | 04:08 PM
GrayGlenn's Avatar
GrayGlenn
Cruising
Default Re: A4 Shift Points (IMQUIK)
Could you describle in more detail how you car shifts. Is this something that is easy to do or do I need to find someone to have this done. Thanks
Old May 18, 2004 | 04:16 PM
IMQUIK's Avatar
IMQUIK
Here is mine, I have 3.73's & SS-3600
1-2 38-mph
2-3 74
3-4 124
2-1 36
3-2 71
4-3 120
1-2 6200 rpm
2-3 6200
3-4 6000
Old May 18, 2004 | 05:10 PM
bgood's Avatar
bgood
:confused: Those aren't the shift points I suggested.. here is what I sent:
1-2 38
2-3 73
3-4 119
2-1 33
3-2 69
4-3 115
RPM
1-2 6000
2-3 5900
3-4 5900
The PCM must meet both conditions of RPM and MPH before the WOT shift. Again this is only for WOT. The part throttle tuning has a little more complex shift table.
Old May 18, 2004 | 06:30 PM
TLKSCHP's Avatar
TLKSCHP
To conservative for me, i like the 6200 rpm wot. But the Rev needs bumped up to, say 6500. I have a friend shifting at 6500 and it pulls real nice their.
Old May 18, 2004 | 06:46 PM
BHP's Avatar
BHP
Example of stock normal shift points (based on TPS%) that you can edit in LS1-Edit:
1-2:11 11 12 13 15 19 22 25 28 31 33 35 36 37 38 38 38
2-3:18 18 21 23 27 33 39 45 51 56 61 65 69 71 73 74 75
3-4:24 24 29 35 41 48 56 85 108 119 127 131 133 133 133 133 133
2-1:9 9 10 10 10 10 10 10 10 10 10 10 10 10 10 10 35
3-4:16 16 16 16 16 16 18 20 23 26 31 35 40 45 50 57 74
4-3:22 22 23 25 29 32 37 42 48 55 66 82 94 100 107 114 129
Old May 18, 2004 | 06:50 PM
bgood's Avatar
bgood
Default Re: A4 Shift Points (Tlkschep)
For a stock A4 C5 LS1 the optimal place to shift is near the 6000 rpm mark. The stock cam has already started dropping HP at that point. The stock valves will begin to float around 6200 rpm. I do not see much gain over the additional wear of the valvetrain. However if you have a cam w/upgraded springs then I can understand the need to move the shift points to a different location.
Old May 18, 2004 | 08:10 PM
Greg5's Avatar
Greg5
Does changing the shift points change the way the shift feels? My car shift fine at low speeds however when I step on it from zero, it feels as if it's gliding into second. I have a Ford Crown Vic police interceptor that I drive at work and it does the same thing. Problem or "that's the way it is"?
Old May 18, 2004 | 09:14 PM
corvettebob1's Avatar
corvettebob1
Default Re: A4 Shift Points (Greg5)
Changing the shift points in no way affefects the shift feel! :D
Shift feel is controled by main line pressure and accoumlator rate or pressure and clutch clearence.
Just because it shifts hard dosen't mean it will last long!!!!! :D
Old May 18, 2004 | 09:50 PM
Mr Cowl Hood's Avatar
Mr Cowl Hood
I tune Fords and GM's and they both have shift pressure tables for every gear and range from part throttle to WOT. They are based on the % TPS and adjusting these will make the shifts firmer or less firm so it's wise to be careful when altering shift presures. Both manufacturers make soft shifts in the stock tables to make your ride more pleasant. There's lots of room for firmer shifts without breaking anything. :cool:
Shift parameters like 1-2, 2-3, etc are on other tables and are based on % TPS and mph. Just like the above posts. Good discussion! :cheers:
[Modified by Mr Cowl Hood, 8:51 PM 5/18/2004]
Old May 19, 2004 | 05:18 AM
LBear's Avatar
LBear
Default Re: A4 Shift Points (Mr Cowl Hood)
I had the following done to my A4:
Removed TMS, quickened shift times, increased line pressure from 83psi to 86psi
I believe that the above items are SAFE to do and actually can increase the life of the transmission.
Old May 19, 2004 | 07:30 AM
IMQUIK's Avatar
IMQUIK
1-2 38
2-3 73
3-4 119
2-1 33
3-2 69
4-3 115
RPM
1-2 6000
2-3 5900
3-4 5900
That's them!!! :hurray:
Old May 19, 2004 | 09:54 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
This is a great thread, thanks for the info :cheers:
I order HP tuner software and will making some adjustments next week
[Modified by runamuk, 8:55 AM 5/19/2004]
Old May 19, 2004 | 01:12 PM
Demented's Avatar
Demented
Default Re: A4 Shift Points (runamuk)
Why would you have 1-2nd as your highest shift point? It's the gear that needs the most cushion between rev limiter and shift. I have
5950 1st-2nd
5990 2nd-3rd
With the limiter@6300
I tried as high as 6050 but the car would bounce the limiter every time so I had to back them down. It seems that the car needs atleast 300 RPM's to shift. This is with +10% shift preasure -10% shift time on my predator.
To A4 Shift Points
Old May 19, 2004 | 04:10 PM
AMGPilot's Avatar
AMGPilot
Default Re: A4 Shift Points (Demented)
I am interested in having my shift points adjusted, increasing the line pressure and removing the Torque Management System (TMS).
Where could I get this done around the DFW area and what would it cost (approximately) :) Thanks.
Old May 19, 2004 | 04:37 PM
KRK's Avatar
KRK
I'm confused... wouldn't these shift points apply to 3.42's w/ SY3500 as well?
1-2 38
2-3 73
3-4 119
2-1 33
3-2 69
4-3 115
RPM
1-2 6000
2-3 5900
3-4 5900
[Modified by KRK, 4:15 PM 5/19/2004]
Old May 23, 2004 | 09:05 PM
Mr Cowl Hood
Default Re: A4 Shift Points (Yellow2K4)
Doesn't Speedworks do that? I tuned a few cars there before and I thought they were getting set up to tune LS1's. :confused:
