Cleaning MAF Sensor?
Old May 19, 2004 | 08:48 AM
JCR's Avatar
JCR
Default Cleaning MAF Sensor?
How does one clean the sensor?. I have a KN Filter that I think imparted some oil residue on the wires. Any suggestions/ tips.. thanks
Old May 19, 2004 | 09:24 AM
stevenll's Avatar
stevenll
Default Re: Cleaning MAF Sensor? (JCR)
I clean mine with electrical contact cleaner from Radio Shack and a Q-tip.
I have a Halltech TRIC and clean the wires every other re-oil.
It's easy to do. Just be gentle with the Q-tip.
Old May 19, 2004 | 10:01 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Yes, that works great. You can also use some alcohol, as I have done in the past. Contact cleaner is a little bit better though.
Old May 19, 2004 | 10:05 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Cleaning MAF Sensor? (stevenll)
What will be the effects I can feel during driving, when the MAF is covered with filter oil? Could it produce pinging on decent accelerating in 4th gear auto?
I have the Blackwing for 15 kmiles now and never cleaned MAF. Is it time to clean it?
Frederik
Old May 19, 2004 | 05:24 PM
carpe dm's Avatar
carpe dm
Default Re: Cleaning MAF Sensor? (C5 Frederik)
No hurry Frederik,as you are not having any problems. The next time you have it apart (or feel like a new project) do as they did above, with contact cleaner and a Q-tip..... very carefully. :yesnod: :)
Old May 19, 2004 | 09:43 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Cleaning MAF Sensor? (carpe dm)
I use de-natured alcohol and a Q-tip.
Old May 20, 2004 | 11:59 AM
VetteDrmr's Avatar
VetteDrmr
Frederick,
If the MAF sensors have some kind of contaminant on the wires, the MAF translates that as less air flow than the engine is actually getting because the sensor wires are insulated from the air flow. This will naturally cause the engine to go lean, even as the rest of the fuel system is trying to compensate. Voila, there's your pinging.
So, if you're coming up against a detonation issue, I'd clean the MAF first, it's just too easy to do, and it eliminates one variable.
HTH, and have a good one,
Mike
Old May 20, 2004 | 09:53 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I would not use a q-tip.. one slip and you brak one of those wires and your out 400 dollars... CRC contact cleaner, or radio shack contact cleaner spray are all you need...
Old May 20, 2004 | 10:13 PM
BigTodd's Avatar
BigTodd
Default Re: Cleaning MAF Sensor? (Evil-Twin)
Make sure the contact cleaner is non residue, you might replace one film with another... :yesnod:
Old May 21, 2004 | 02:36 AM
Avanti's Avatar
Avanti
We once fought a custom electronic F-I, supercharged install only to find we had once sucked in some oil into the sensor via a misplaced crankcase vent line. Cleaned the MAF and it made all the difference in the world.
Check that the contact cleaner doesn't have a "lubricant." One I've seen at RadioShack does.
All the best. :yesnod:
To Cleaning MAF Sensor?
