Flashing check engine light
Old May 19, 2004 | 08:57 PM
Dicecal's Avatar
Dicecal
Default Flashing check engine light
Recently I've been getting a flashing check engine light accompanied with a rough running engine for a few seconds under light acceleration, med-high rpm, low speed and lower gears (1st, 2nd). The engine begins to smooth out and the check engine light eventually goes out after a few seconds. Just an intermittent problem, and no associated codes. Any Idea whats going on? Thanks in advance.
Old May 19, 2004 | 09:02 PM
DsC5's Avatar
DsC5
Default Re: Flashing check engine light (Dicecal)
had the same problem a bit ago, might be a bad plug wire - I have since changed both plugs and wires, and no check engine light.
http://forums.corvetteforum.com/zerothread?id=815378
Old May 19, 2004 | 09:33 PM
blackjack's Avatar
blackjack
Make sure that your fuel cap is installed properly also.
Old May 20, 2004 | 12:03 PM
VetteDrmr's Avatar
VetteDrmr
The flashing light is indicating you've got a misfire happening, then as it clears up the light goes out. There's not a code associated with it, but if you have access to Autotap or something similar the PCM keeps a history of what cylinder the misfire is occurring at.
HTH, and have a good one,
Mike
Old May 20, 2004 | 12:26 PM
mwittkopf's Avatar
mwittkopf
Default Re: Flashing check engine light (VetteDrmr)
Mike
Mike is correct. If you cannot get a scanner to see what cylinder it is happening to, definitely make sure your plug wires are on all of the way and not burnt. If that doesn't help and you are up to it, I would change the plugs and wires.
We just had a car in yesterday that actually had a broken pushrod (looked like it had been bent for awhile) that caused the problem.
It definitely helps to have a scanner to narrow it down for you!
Mike
To Flashing check engine light
