Spark Plug Wire
Old May 20, 2004 | 11:27 PM
johnlovescar's Avatar
johnlovescar
Default Spark Plug Wire
I am in the process of looking for new set of spark plug wire. My car currently have 8,500 miles. I am not sure if I should go with MSD 8.5 mm or Taylor 10.5mm. I currently have NGK Iridium spark plug and K & N air charger. Thank You in advance for any help.
:banghead:
Old May 20, 2004 | 11:52 PM
gonbad's Avatar
gonbad
Default Re: Spark Plug Wire (johnlovescar)
I went with the MSD wires because the stock heat shields will still fit.
Old May 21, 2004 | 12:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
johnlovescar
Spark plug wires are NOT going to put you into the 10 second bracket. If your wires are in good shape I doubt if you will see any HP or torque changes at all. On the other hand If you have BAD wires, changing them out with better wires will make a difference.
Check your wires with an OHM Meter. they should read around 300-400 ohms. If they are greater than about 500-600 OHMS or the outer jacket is damaged, they are about ready for replacement! :thumbs:
If they are in the MEG OHM range, GET NEW WIRES!
I would purchase wires that can use the STOCK HEAT shields. :yesnod: They seem to last longer unless you use heat socks. I used MAGNACORES and they seem to work fine.
Bill Curlee
Bill
[Modified by Bill Curlee, 11:42 PM 5/20/2004]
Old May 21, 2004 | 08:19 AM
Miaugi's Avatar
Miaugi
Default Re: Spark Plug Wire (gonbad)
:iagree:
Old May 21, 2004 | 09:57 PM
johnlovescar
Default Re: Spark Plug Wire (Miaugi)
:iagree: Thanks everybody............I think will will go with MSD.
:auto:
To Spark Plug Wire
