raptor shift lite
Old May 21, 2004 | 02:27 PM
wrustywrench's Avatar
wrustywrench
Default raptor shift lite
hooked up may raptor shift lite AT THE DRIVERS SIDE, if anyone is doing an shift lite install, no need to go to the pass side for tach wire,,,just do a search and find the install how to,, it works great....got power and ground for mine at my boost guage.....took me 1 hour to install it...Did have on snafu, the screw at the interior temp sensor , if I tighten it down, it caused my ignition switch to bind and fail to return when starting the car, loosen the screw and all is fine....the shift lite works great...
Old May 21, 2004 | 03:07 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: raptor shift lite (wrustywrench)
:thumbs: I put that link in my sig :yesnod:
Old May 21, 2004 | 03:40 PM
Watch22's Avatar
Watch22
Default Re: raptor shift lite (Flyin'Brian)
I went from the drives side also for my Harlan shiftlight. It was easy the total install was under 1 hour.
To raptor shift lite
