Problem with power door locks.
Old May 22, 2004 | 11:42 AM
sonny9201's Avatar
sonny9201
Default Problem with power door locks.
The drivers door power lock will not unlock with the remote or with the door button. Manually it will unlock from either inside or outside the car. The dealer just replaced the actuator and it worked for a day.
Old May 22, 2004 | 12:34 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Problem with power door locks. (sonny9201)
:banghead: ..mine is intermittent sometimes...I guess when it dies I will fix it
Old May 22, 2004 | 09:30 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
in the front of the drivers side door, there is an accordian looking rubber duct ... inside that duct are the power wires that go to the actuator door control module.. there can be a pinched wire in there.. looks specifically at the orange and the brown wires..
Old May 22, 2004 | 09:42 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
Hmmmm, I had intermittent driver door issues with all the door controls. The wire harness in the door was being over stretched when the door was swung FULLY open.................fixed now..........
Not sure it is the same for you........................
Old May 23, 2004 | 03:59 PM
FKING1's Avatar
FKING1
Default Re: Problem with power door locks. (Buckmaster)
Mine does this if the car sits for a week or so. Using it every day it works fine. The car is trying to tell me something.
Fred K.
:steering:
Old May 24, 2004 | 12:41 AM
fdxpilot's Avatar
fdxpilot
Had the same problem on my 02, and the dealer put in a new Door Control Module.
To Problem with power door locks.
