NEED QUICK HELP! broken plastic tube in engine compartment.
Old May 22, 2004 | 01:43 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default NEED QUICK HELP! broken plastic tube in engine compartment.
hey guys, just under the car and noticed a small (~1/8"OD), clear plastic tube coming out of the driver side of the transmission tunnel toward the engine compartment. it was broken (i assume) and just hanging there. it appears to be some type of vacuum tube as far as i can tell but i have no idea where it goes. does this sound familiar to any of you? tell me where this thing goes.
also, noticed that the hose from radiator to W/P is collapsed. is this normal when the engine is off?
Old May 22, 2004 | 03:07 PM
User 81424's Avatar
User 81424
Default Re: NEED QUICK HELP! broken plastic tube in engine compartment. (clutchdust)
Are you asking about your 81 or a C5? I don't recall seeing a clear tube on a C5, I could be wrong.
As the engine cools the cooling system should suck in air and not collapse your hoses, you have a stuck radiator cap or an old, weak hose. I think.
Old May 22, 2004 | 03:08 PM
IronJen's Avatar
IronJen
Abby Normal
o.k. figured out what the tube was. :bb previous owner was going to install a gauge, that was the tube.
still want to know about that hose though. is that normal?
Old May 22, 2004 | 03:20 PM
User 81424's Avatar
User 81424
No it's not good.
Old May 22, 2004 | 04:25 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: NEED QUICK HELP! broken plastic tube in engine compartment. (CPT Z06)
No it's not good.
:iagree:
more than likely it's the cap on the coolant overflow tank
Old May 22, 2004 | 04:56 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: NEED QUICK HELP! broken plastic tube in engine compartment. (runamuk)
________________________________________ ________________________
Change the overflow tank cap. I had the same problem on my car. The new cap is the same part number........but upgraded.
Old May 23, 2004 | 08:43 PM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
I would think the hose needs to be replaced as well - it shouldn't collapse :nonod:
To NEED QUICK HELP! broken plastic tube in engine compartment.
