Head Gasket for 99 LS!
Old May 24, 2004 | 09:32 PM
cbota's Avatar
cbota
Default Head Gasket for 99 LS!
Hi All,
Which is the best head gasket to use when changing heads in a 99, what are the difference in the GM gaskets for 99 and the 2003 heads. Thanks :seeya
Old May 24, 2004 | 10:00 PM
MrEracer's Avatar
MrEracer
Default Re: Head Gasket for 99 LS! (cbota)
The early gasket is a black composite gasket and works fine on any 346 engine. The newer gasket is a sandwich gasket very similar to the Cometic gasket and is better than the older gasket, especially in high HP applications. They are both fairly cheap through Scoggin-Dickey Parts department.
Shirl
SDRE
Old May 24, 2004 | 11:10 PM
Chris@SD's Avatar
Chris@SD
Default Re: Head Gasket for 99 LS! (MrEracer)
THe black gaskets are actually the 6.0l truck gaskets and the bore is a little too large to use on the stock LS1. The stock early LS1 gaskets are very light grey in color.
Sorry, just being nit-picky...
To Head Gasket for 99 LS!
