Getting clutch installed
Old May 26, 2004 | 10:31 AM
Ben01C5's Avatar
Ben01C5
Default Getting clutch installed
Should I replace the slave and master or just the slave?
My clutch has been sticking for a while if I take it up in the rpm's and bang a gear. Should I just change them both to be safe?
I am putting in a SPEC III and Aluminum flywheel.
Ben
Old May 26, 2004 | 12:07 PM
C5 CU's Avatar
C5 CU
Default Re: Getting clutch installed (Ben01C5)
probably best to upgrade to 02-04 slave. master and consider the drill mod...
Old May 26, 2004 | 12:12 PM
silverz06vette's Avatar
silverz06vette
Also get one of those bleeder extensions from LAPD. That way you can bleed in 5 mins instead of 5 hours.
Old May 26, 2004 | 01:48 PM
Ben01C5's Avatar
Ben01C5
Default Re: Getting clutch installed (C5 CU)
What exactly is the drill mod?
Old May 27, 2004 | 09:22 AM
Ben01C5's Avatar
Ben01C5
I ordered the slave and master from fitchner Chevy for 90 bucks a peice. My local dealer wanted $145 a piece. :rolleyes:
Old May 27, 2004 | 10:15 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
The drill mod removes the restruction(s) in the line between the master cylinder and slave which are meant to slow down the movement of the clutch to ease shock to the drive train from the disk engaging so quickly. This is not suitable for racing/enthsiast type driving so you drill out the restriction to allow the clutch to engage/disengage quicker. The F-Body guys do it all the time. Us Y-Body guys actually have three restrictions and two are a ***** to get to. Check this out.
http://forums.corvetteforum.com/zerothread?id=821371
[Modified by 5 Liter Eater, 9:15 AM 5/27/2004]
To Getting clutch installed
