idle problem
Old May 26, 2004 | 12:29 PM
pdykinga's Avatar
pdykinga
St. Jude Donor '04 & '05
Default idle problem
In my reasearch I found quite a few people having idle problems after installing an itake system. I am just about to order mine but now I am having reservations. I do not want to have to reset the ecu everyime I go for a spin.
Also I would really like to buy the twin filter intake, is there really a serious turbulence problem? I am not looking for max power, just a bit more :)
thanks!
Pete
[Modified by pdykinga, 12:01 PM 5/26/2004]
Old May 26, 2004 | 11:34 PM
mdhmi's Avatar
mdhmi
Default Re: idle problem (pdykinga)
Huuuhhh ?? I haven't had any problems with either my LS6 intake or my Blackwing.
Mark
Old May 27, 2004 | 12:24 AM
bandit_99's Avatar
bandit_99
? You can follow the instructions for a relearn. Doesn't take long and should address idle problems. I never bothered with a relearn after the intake or breather and idle was fine. I did have problems from a ported throttle body- but that's a diferent story (and even that is pretty rare).
And by the way, there are cheaper and better performing intakes than the dual cone intake. A few years ago, it was ok- but take advantage of something newer, better, cheaper- Halltech makes a nice unit with an airbridge for like $200- The blackwing is about the same price ... Varam gets good press, but is more involved to install. Take a look around as I'm sure there are more than what I noted.
Good luck
:cool:
Old May 27, 2004 | 12:31 AM
rarfinacial's Avatar
rarfinacial
Default Re: idle problem (bandit_99)
Were can I find the instuctions for a relearn? :confused:
To idle problem
