How much intake modding can the computer adjust for?
Old May 29, 2004 | 11:06 PM
yellow01's Avatar
yellow01
Default How much intake modding can the computer adjust for?
I'm curious how much modding you can do on the intake before fuel supply becomes an issue. Maybe this is a dumb question, but I'm just curious how far the computer can adjust.
Clearly everyone does the standard intake (new filter, cold air etc), then many add the air bridge, new MAF, bigger throttle body etc. Can all this be done with no need to increase fuel? (i.e. bigger injectors etc?)
Old May 30, 2004 | 06:34 PM
rwj383's Avatar
rwj383
Default Re: How much intake modding can the computer adjust for? (yellow01)
If I understand your question correctly, you're asking how much hp is the fuel injectors/system good for? -stock fuel injectors are good for ~450rwhp (some push them considerably more). The fuel system is good for ~575rwhp. You will not see these numbers with strictly bolt-ons and a stock motor, so you will be fine. However, you will need to tune your pcm for optimum results as you bolt on more items such as headers and bigger intake/TB.
The pcm will not automatically adjust for your mods until LTFTs go beyond +/-25% of stoic at part throttle (closed loop) driving. And even so, this would never be optimum part throttle tuning. In addition, the computer will not adjust any WOT/PE parameters on its own at any time. This is why you will want to consider pcm tuning once you get beyond the more basic bolt-ons such as cold air filter and cat back exhaust. If you put on a full LT header system and bigger intake & TB, you will need tuning.
Robert
http://www.gen3motorsports.com
[Modified by rwj383, 3:39 PM 5/30/2004]
Old May 30, 2004 | 07:44 PM
allanlaw's Avatar
allanlaw
I think it's OK till you get to major stuff like turbo's, SC, nasty cams, bigger heads, etc.
To How much intake modding can the computer adjust for?
