Throttle Cable Conversion Kit for C5??
Old Jun 24, 2004 | 03:43 PM
GoldMember's Avatar
GoldMember
Default Throttle Cable Conversion Kit for C5??
I am converting my C5 to an FBody style Trottle Body setup, this means switching from "Fly by Wire" to a true throttle cable. Someone on here mentioned to me a while back that someone makes and sells a conversion kit for this, that includes the trottle cable, brackets, fittings ect. ?
anyone heard of this or know where I can get it ?
Thanks !
Old Jun 24, 2004 | 03:46 PM
Blkout's Avatar
Blkout
Default Re: Throttle Cable Conversion Kit for C5?? (GoldMember)
I know of NO kits available and would have to ask. Why would you want one?
[Modified by Blkout, 8:46 PM 6/24/2004]
Old Jun 24, 2004 | 03:52 PM
GoldMember's Avatar
GoldMember
Default Re: Throttle Cable Conversion Kit for C5?? (Blkout)
Its not your avg. street C5, I am running a FAST 90MM TB with a sheet metal intake, I am also swithing to a Gen 7 DFI or Big Stuff 3 SEFI(undecided yet) and in which case neither will support a "fly by wire" setup.
Old Jun 24, 2004 | 03:57 PM
Blkout's Avatar
Blkout
Gotcha!
Old Jun 24, 2004 | 08:07 PM
Gus's Avatar
Gus
Cruise-In III Veteran
Item # LOK-TC-1000LS1U Throttle Cable Black LS1 36"
You can order it through Summit, but its on back order.
Old Jun 25, 2004 | 09:37 AM
Guest
Guest
Posts: n/a
Default Re: Throttle Cable Conversion Kit for C5?? (Gus)
An f-body cable will work too, and the braided version of th lokar cable is in stock, but you need to fab a new pedal arrangement. The fly by wire TB still has a TPS on it, isn't that all the FAST/big stuff system needs? The motor that controls the TB blade operates independently from that, and has it's own control box. The two might be able to co-exist.
Old Jun 25, 2004 | 10:49 AM
GoldMember's Avatar
GoldMember
Default Re: Throttle Cable Conversion Kit for C5?? (ASP Z)
Your right there is a seperate control unit "TAC" that controls the trottle blade solonoid on the fly by wire system, the only prob is it has a serial connection that runs through the PCM, and will not work without it, since the PCM is replaced by the DFI I cant go that route.
I am also running the FAST 90MM TB which has a Air Idle Bypass, which a vette does not have either, so I have to run an Fbody style DFI/PCM harness as well.
I think I am just going to try and order a stock Fbody cable as it will fit the Tbody nicely, and then fab something up on the pedal.
Old Jun 25, 2004 | 11:48 AM
Guest
Guest
Posts: n/a
Aha, makes sense now. I'd only seen it used whre the pcm was retained in the conversion. Hope you get it all running soon.
To Throttle Cable Conversion Kit for C5??
