Questin for LG header guys
Old Jun 24, 2004 | 07:33 PM
C7LOU's Avatar
C7LOU
Default Questin for LG header guys
I have LG's with the RT cats on my Z06. I notice more sound under the car now than before. I've checked and rechecked for leaks and can't find any. I've laid under the car with it on ramps and running and I can't pinpoint one place and I see no soot marks or condensation leaks. My pipes are all welded (clamped at the collector of course) because I couldn't keep my Stingers aligned without. The sound I hear is almost like a tinny air sound if that makes sense. I notice it more if I accelerate and there's a car or wall or something next to me where I get the rebound sound of that car or wall.
Would I see soot or some evidence if it's leaking at a connection somewhere? Is this just normal engine noise which is louder due to the thinner pipe walls? I'm stumped.
Old Jun 24, 2004 | 07:46 PM
dpd's Avatar
dpd
Default Re: Questin for LG header guys (C5LOU)
i have the same sound on mine[03 z06 w/lg's],if i'm not mistaking,i believe it's due to the step in the collector[which creates the venturi effect].
Old Jun 24, 2004 | 07:49 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
That tinny sound is normal of a car equipped with headers. I think what you are hearing is totally normal. If it were leaking you would see the carbon/soot at the leak.
Old Jun 24, 2004 | 08:12 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: Questin for LG header guys (Z06ufgrad2002)
I get the same tinny noise with my LGM LT headers w/ cats. I thought it was a leak too - but appears to be normal.
Old Jun 24, 2004 | 09:11 PM
HalfMoon's Avatar
HalfMoon
Yep. Nomal.
Drove me nuts on my First LS1 Header car. I always thought I had a leak.
Take a look at your stock mid section and compare the thickness of the pipes versus the LG pipes. The Stock part on my '04 looks to be double walled by the pup cats.
More Power = More Noise.
Old Jun 24, 2004 | 10:00 PM
C7LOU's Avatar
C7LOU
Default Re: Questin for LG header guys (Tony_C5_04)
Thanks for all the replies! I can relax now!
Old Jun 25, 2004 | 07:47 AM
vettenuts's Avatar
vettenuts
Default Re: Questin for LG header guys (AlohaC5)
Don't have them yet, but on my previous header cars I heard the same sound you describe.
Old Jun 25, 2004 | 10:37 PM
007Duc's Avatar
007Duc
Default Re: Questin for LG header guys (vettenuts)
Yup! It's normal. The stock cast manifolds muffle a lot of the valve train and combustion chamber noise out and that's what you hearing through the thin wall stanless tubes.
To Questin for LG header guys
