need help quick with lg header issue
Old Jun 24, 2004 | 07:47 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
Default need help quick with lg header issue
i have a z06, with lg headers, can i reuse the stock gaskets
Old Jun 24, 2004 | 07:52 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: need help quick with lg header issue (RyneZ06)
I wouldn't.
Get a new set of GM LS1 exhaust gaskets.
If your pressed for time; use the ones that came with the headers but, be prepared to replace them if/when they begin to leak.
dpd's Avatar
dpd
i wouldn't.when i did mine,the dealer sent me the wrong gaskets,so i used the ones that came with the headers[i was in a pinch],i used locking header bolts and tightened them up evenly,so far so good,no leaks[2000 miles since install].
Old Jun 24, 2004 | 07:58 PM
Former Vendor
Default Re: need help quick with lg header issue (Z06ufgrad2002)
i got them already installed using the gaskets provided, but i am doing a clutch swap tomorrow
Old Jun 24, 2004 | 08:06 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Depends on how many miles you have on the car. I would use the stock GM gaskets over the cheap Borla gaskets provided with the headers. I reused mine on my '04 with no problems. However, if you have several thousand miles on the vette, then you may want to purchase a new set of OEM gaskets.
Old Jun 24, 2004 | 09:06 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I believe Lou recommends "Factory" gaskets.
Bob
Old Jun 25, 2004 | 12:22 AM
Avanti's Avatar
Avanti
Simple... this much time, work, and $$$, get the new factory gaskets. & be happy.
Old Jun 25, 2004 | 07:59 AM
wrustywrench's Avatar
wrustywrench
Default Re: need help quick with lg header issue (Avanti)
I have installed many headers, the fiber gaskets are JUNK, get oem at the dealer ...I did and never had a problem on my ls1,,retighten them after a few heat cycles and youll be fine,,,dont be a gorrilla with the head bolts and use antiseize....
Old Jun 25, 2004 | 10:33 PM
007Duc's Avatar
007Duc
Default Re: need help quick with lg header issue (wrustywrench)
Lou recomends oem gaskets and the LS1s at that not the LS6 gaskets as the exhaust port is a diffenent shape and the LS1s fit the header better, the supplied gaskets are junk as stated earlier.
To need help quick with lg header issue
