Is the corsa X-pipe worth while doing?
Old Jun 25, 2004 | 02:39 PM
Z06Fix's Avatar
Z06Fix
Default Is the corsa X-pipe worth while doing?
hey guys just started to mod and I was wondering if it is worth while doing when I put on the Z06 ti's. also is it any better or worse than any of the others?
Old Jun 25, 2004 | 03:17 PM
mdhmi's Avatar
mdhmi
Default Re: Is the corsa X-pipe worth while doing? (00BlkFRC)
The X-Pipe is definitely worth while for an M6. Is your FRC an M6 or A4?
Mark
Old Jun 25, 2004 | 04:24 PM
birch64's Avatar
birch64
Default Re: Is the corsa X-pipe worth while doing? (mdhmi)
why would it make a differance a4 or m6 ? just ordered a magnaflow x-pipe, from west coast corvette. they say mangaflow is a true crossover x-pipe.......will be using it with GHL's. 2000 coupe a4..........
[Modified by birch64, 9:25 PM 6/25/2004]
[Modified by birch64, 9:27 PM 6/25/2004]
[Modified by birch64, 12:12 AM 6/26/2004]
Old Jun 25, 2004 | 07:37 PM
OutlawDon's Avatar
OutlawDon
Go for it.....Magnaflow or Corsa....good mod. I give it an A rating.
Old Jun 25, 2004 | 07:41 PM
Laguna Blu's Avatar
Laguna Blu
Default Re: Is the corsa X-pipe worth while doing? (OutlawDon)
Definitely smooths out the exhaust sound. Less motorboat gurgling. If you like the popping on decel, then don't add the pipe.
Old Jun 26, 2004 | 12:38 AM
Z06Fix's Avatar
Z06Fix
it's an M6
Old Jun 26, 2004 | 12:59 AM
jrose7004's Avatar
jrose7004
Do the X-Pipe and you won't be sorry!
Old Jun 26, 2004 | 01:13 AM
Z06Fix's Avatar
Z06Fix
well a buddy of mine and I put on the corsa pipe today and I'm getting an annoying humm almost vibration right at 1400rpm that wasn't there before. what is causing this and what can I do about it? will changing out the rear sec fix this prob??
thanks Eric
Old Jun 26, 2004 | 10:05 AM
Flareside's Avatar
Flareside
These exhaust systems are a real pain to get right! I first installed the Z06 exhaust with the stock H pipe, and loved the quality and lack of resonance, but it was just too quiet. Next, I bought a GHL bullet exhaust and loved the new volume level, but couldn't deal with the popping. A Corsa X pipe cured that by about 50%, but also increased the cruise resonance. It's pretty annoying in the 1800-2000 area for me.
I'm not sure what my next move will be, the GHLs are growing on me, so I'm not sure I could go back to the quiet Z06. I can tell you this: If I put the Z06 back on, I'll also reinstall the stock H pipe. The X takes the edge off the sound, and the Ti doesn't need that.
[Modified by Flareside, 10:06 AM 6/26/2004]
To Is the corsa X-pipe worth while doing?
