CLB fixed...how do I know?
Old Jun 25, 2004 | 04:02 PM
fmpros's Avatar
fmpros
Default CLB fixed...how do I know?
Quote:
The 97'-00' A4's have the locking plate removed from the steering column during the current recall. A CLB is NOT required for these models after the current recall is performed as the steering column can't lock up without the locking plate. On some '97 & 98's, installing the CLB will throw codes.
How do I know if the locking plate on my 2000 has been removed from a recall? I've got a CLB ready to go on but not if this has ocurred.
Old Jun 25, 2004 | 05:43 PM
Patches's Avatar
Patches
Default Re: CLB fixed...how do I know? (fmpros)
If you can turn your steering wheel without the key in the ignition (i.e., column is not locked in position), then you no longer have a functional column lock. If that's the case, congrats.
Best of luck.
Old Jun 25, 2004 | 08:57 PM
The Exception's Avatar
The Exception
ETCC Ms.Corvette
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '05-'06
Two years ago my '98 locked up, dealer supposedly fixed, then yesterday it locked again and they wouldn't do anything since it had been over 12/12. Thank goodness I was able to get a bypass in a matter of min. and don't have to worry about that happening again.
To CLB fixed...how do I know?
