mass airflow sensor electrical connector removal
Old Jun 26, 2004 | 05:32 PM
david76's Avatar
david76
Default mass airflow sensor electrical connector removal
I am attempting to install RM Racing's Twin Air Intake on my 2002 Convertible. The electrical connection to the Mass Air flow sensor has me stumped. What is the trick to remove this? I appreciate any help.
Also are there any concerns that I should consider when using this air intake system?
Thanks, David
Old Jun 27, 2004 | 12:37 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Default Re: mass airflow sensor electrical connector removal (david76)
I struggled with this too. It's painfully self-evident with benefit of hindsight.
The light colored part is not part of the connector, but a clip that must be slid out first:
...and here is the "finished product":
[Modified by BW1, 9:38 AM 6/27/2004]
Old Jun 27, 2004 | 05:30 PM
david76's Avatar
david76
Default Re: mass airflow sensor electrical connector removal (BW1)
Thank you for the picture and the assistance. You are correct, after the fact it's so simple.
Old Sep 6, 2021 | 06:48 PM
wdcraig's Avatar
wdcraig
An "oldie" but a goodie so I am resurfacing. I struggled to figure out how to unclip the connector when I went to clean my MAF. After the fact, I found this post.
I was experiencing some uneven acceleration over the course of the last year or so, although my car started and ran just fine in the lower rpm range and it was not throwing any codes. I'd replaced the plugs and wires a couple of years ago and was thinking perhaps I had a bad plug, plug wire or coil pack. However, after doing some research, it seemed prudent to rule out a dirty MAF. As luck would have it; cleaning the MAF did the trick and I now I am wishing I had attended to this sooner.
If, like me, you never cleaned your MAF (or it has been a while since you've cleaned it); you might wish to take a few minutes to tend to it. Some folks recommend it be cleaned with every oil change or with every air filter change. From now on, I am going to make it an annual ritual.
Old Sep 23, 2021 | 12:52 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I'm going to chime in and ask what is the best way to clean the MAF. Going over a 98 with 140K miles on it that has been having some stumbling idle issues. I don't think the MAF has ever been touched. Thanks.
Old Sep 23, 2021 | 01:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Remove it and clean with MAF Sensor cleaner…easy to do !!
To mass airflow sensor electrical connector removal
