Car is hitting 230 degrees while standing????
Old Jun 28, 2004 | 12:05 PM
PWR 50X's Avatar
PWR 50X
Default Car is hitting 230 degrees while standing????
I had a flush done recently to my C5. Since then my temperature goes up beyond 220 and sometimes 230 degrees. I have a 160 degree thermosthat and housing. Any idea why this is happening? When will the fan turn on? At what temperature do they start up? Could it be an air bubble in the radiator?
thanks.
Old Jun 28, 2004 | 04:55 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Car is hitting 230 degrees while standing???? (PWR 50X)
I beleive the stock fans tun on at 219/229. So yeah- 230 degrees sounds reasonable in traffic in tthe summer. I've had mine well over 250 after an autocross run.
Try turning on the A/C- the fans automatically come on lower (forget the exact temp) and should keep the temps under 220.
Old Jun 28, 2004 | 05:38 PM
c5freak's Avatar
c5freak
Default Re: Car is hitting 230 degrees while standing???? (Umrswimr)
Changing to a lower temp thermostat won't help unless you change the fan temp settings.
Old Jun 28, 2004 | 05:41 PM
mdhmi's Avatar
mdhmi
Are you using Water Wetter?
Mark
Old Jun 28, 2004 | 05:43 PM
CAPN17's Avatar
CAPN17
Water wetter or purple ice will drop the temp some by improving the heat transfer rate.
Old Jun 28, 2004 | 07:08 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
For later model years:
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
For early model years:
Low speed fans come on at 219,high speed fans come on at 228,low speed with a/c on...
Old Jun 28, 2004 | 07:36 PM
FKING1's Avatar
FKING1
Default Re: Car is hitting 230 degrees while standing???? (Evil-Twin)
There could be an air bubble trapped in the system from the flush. This could cause the problem. There is a way to get it out, but, I have forgotten. Maybe someone else can jump in. Water Wetter will do nothing in anti-freeze. 2 bottles did nothing for my 00 C5.
Fred K.
Old Jun 29, 2004 | 12:22 AM
VETFVER's Avatar
VETFVER
thanks.
The 160 stat only controls the lower temperature. Above 190, I turn my air conditioning on, which turns on the engine fans. My peak temp with fans on is 197. Turn on the air and see what happens.
Dan
Old Jun 29, 2004 | 08:46 AM
PWR 50X's Avatar
PWR 50X
Default Re: Car is hitting 230 degrees while standing???? (VETFVER)
Has anyone reprogramed the fan switch to turn on at an lower temp? The low thermostahat device I installed, I had installed in my C4 and it maintains the level at a lot lower temp. I seen a device that allows you to control the temp in ecklers.
Anyone knows anything about it?
thanks for the help so far.
Old Jun 29, 2004 | 09:47 AM
Umrswimr's Avatar
Umrswimr
St. Jude Donor '05
Take it to a shop that has LS1 edit. They can program the fans to turn on/off whenever ou want.
Old Jun 29, 2004 | 12:43 PM
ersatz928's Avatar
ersatz928
See the $40 adjustable C5 fan controller install article at the top of the Forum, under "Tools", "Tech Tips", "C5".
Old Jun 29, 2004 | 04:23 PM
GOOSE JR.'s Avatar
GOOSE JR.
Default Re: Car is hitting 230 degrees while standing???? (ersatz928)
I've installed the 170 stat and a fan controller,it is working perfect. The fan controller is adjustable and blends in with the rest of the underhood wires. The car hasbeed modified to the point where I needed PCM programming,I used a Vinci unit to program the car and one of the options was what temp the fans turned on so I use this as a back-up.
Old Jun 29, 2004 | 05:25 PM
PWR 50X's Avatar
PWR 50X
Default Re: Car is hitting 230 degrees while standing???? (GOOSE JR.)
what brand?
where did you get it from?
how much?
thanks.
Old Jun 29, 2004 | 05:38 PM
Hiteck's Avatar
Hiteck
Saw where your car has many mods. Get LS1 Edit. Can be a little expensive, but well worth it. I had this done and my fan cuts on at 187 deg. F. Last week it was 100 deg outside. In slow traffic my car got up to 203 deg. 45 minutes of sitting and barely moving in 1st gear. This was with a/c on. But I haven't noticed where turning on my a/c brings down the temp any. But I rarely run a/c. Only if the heat is unbearable.
To Car is hitting 230 degrees while standing????
