CF powerduct install???
Old Jun 28, 2004 | 05:47 PM
pdykinga's Avatar
pdykinga
St. Jude Donor '04 & '05
Default CF powerduct install???
I think I just installed a CF powerduct but it cannot be right? The duct just slips on over the MAS?? I can't image I am supposed to put a clamp on the CF ?? I need a little reassurance?
thanks
Pete
Old Jun 28, 2004 | 05:51 PM
Goody's Avatar
Goody
Default Re: CF powerduct install??? (pdykinga)
All the photos I have seen shows a clamp on each end of the intake tract. So I will say that you need one. Others will likely help out that have them installed.
Old Jun 28, 2004 | 05:59 PM
pdykinga's Avatar
pdykinga
Default Re: CF powerduct install??? (Goody)
I should add that this in an 04 c5
Old Jun 28, 2004 | 10:12 PM
pdykinga's Avatar
pdykinga
After closer inspection, I cannot see how this could possibly be right. The car must be taking in some unmetered air through the small gaps around the MAS. If I put a clamp on the carbon fiber part it will crack the minute I tighten it?? Begging for insight here
Old Jun 28, 2004 | 11:11 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Pete. Youv'e got mail....
Old Jun 29, 2004 | 01:02 AM
pdykinga's Avatar
pdykinga
Default Re: CF powerduct install??? (Threed)
Thanks for that it would appear that I do have everything correct except that because my duct is carbon fiber and I am certain it will crack that minute I tighten a clamp down on it. I guess I should have bought a plastic one in order to tighten it down Anybody find any fix for this?
thanks
Pete
Old Jun 29, 2004 | 06:40 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
silicone duct
Old Jun 29, 2004 | 07:42 AM
AFVETTE's Avatar
AFVETTE
I have a BW, CF duct and silicon coupler. The air bridge just nestles up to the maf and there is no clamp. My works fine.
Take a look
Tom
Old Jun 29, 2004 | 08:12 AM
blk05coupe's Avatar
blk05coupe
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: CF powerduct install??? (AFVETTE)
Tom
no clamp? how does it stay on during acceleration with the engine torque and twisting? isn’t there an air leak at the slot at the MAF with no clamp?
Old Jun 29, 2004 | 09:40 AM
pdykinga's Avatar
pdykinga
this is exactly what I have, but I am concerned about any unmetered air being sucked in. I was thinking about putting a bead of glue or electrical tape around the gap but I think it might take away from the looks. Or maybe cut off a small piece of the coupler and use that?
thanks!
Pete
Old Jun 29, 2004 | 09:59 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I have a Halltech TRAP CF bridge. I have clamps on both ends.
Old Jun 29, 2004 | 10:10 AM
AFVETTE's Avatar
AFVETTE
As I recall it slips over the MAF by about 1/2 an inch. There is a notch that keeps everything aligned. It won't come apart with engine torque. Trust me and the folks that sell these. Just install it as it comes.
Trial fit it and see for your self. You can always add a small piece of duct tape to where it mates to the MAF to help seal it but nothing was said about it in the instructions.
Have you contacted the vendor for clairification?
Tom
Old Jun 29, 2004 | 10:56 AM
pdykinga's Avatar
pdykinga
Default Re: CF powerduct install??? (Umrswimr)
and the CF has not split?
thanks!
Pete
Old Jun 29, 2004 | 11:31 AM
AFVETTE's Avatar
AFVETTE
thanks!
Pete
Not sure what would cause it to break. I have no issues installing it the way it came fro WCC. I followed their instructions.
Tom
Old Jun 29, 2004 | 11:36 AM
pdykinga's Avatar
pdykinga
sorry I was replying to the gentleman who said he had clamps on his
thanks
Pete
Old Jun 29, 2004 | 06:38 PM
ZOsix's Avatar
ZOsix
I reused the clamp that was on my stock bridge.
My cf bridge had 2 slots cut in it for tightening it down at least that was what I thought they were for.
I have it tighten down pretty good . No problems yet.
[Modified by ZOsix, 5:40 PM 6/29/2004]
Old Jun 29, 2004 | 07:03 PM
pdykinga's Avatar
pdykinga
Default Re: CF powerduct install??? (ZOsix)
Well I took it all apart and instead of putting a clamp on it, I wrapped the exterior of the MAS with a bit of elec tape, then slid the CF duct on. It was much more snug but I also added a couple layers of elec tape on the outside to seal the gaps up. You can hardly notice the black tape unless you really jam your head down in the engine bay. Seems to be holding together
thanks
Pete
To CF powerduct install???
Old Jun 29, 2004 | 08:28 PM
Threed's Avatar
Threed
Pete maybe I'm reading to much into your question but, I just re-read your question. You reuse the rubber connector on the MAF. It is suppose to slide into the rubber conector on the MAF not over the MAF. You can then tighten it up as tight as a calmp can be tightened.
Old Jun 29, 2004 | 08:35 PM
hightest's Avatar
hightest
you're supposed to re-use the original rubber connector.
You are sucking in unfiltered air otherwise.
Aft of the filter, all connections should be sealed with rubber connectors and clamps.
Old Jun 29, 2004 | 09:25 PM
pdykinga's Avatar
pdykinga
Default Re: CF powerduct install??? (hightest)
hmm are there differences between years? On mine the stock duct is plastic and slips over the MAS with a clamp to tighten it down. There is no rubber connector, just the duct itself that slips over the MAS unit. So by replacing the plastic duct with a Carbon Fiber one that is not as flexible as the stock plastic one, it would crack if I were to tighten it down with the same clamp.
Sorry, its a bit tricky to explain in words
Thanks!
Pete
