Codes HELP!
Old Jun 28, 2004 | 11:39 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Default Codes HELP!
I pulled 2 codes B0361 Left Actuator Feedback Short/gnd
and B0441 Left actuator out of range
What does this mean car is running fine. If I clear them they come right back
Old Jun 29, 2004 | 12:45 PM
navy99vert's Avatar
navy99vert
Default Re: Codes HELP! (navy99vert)
anyone
Old Jun 29, 2004 | 01:15 PM
Logandiagnostic's Avatar
Logandiagnostic
Hahaa......no wonder it took me forever to find the codes. From the post I thought you were having a electronic shock problem.....
They are HVAC codes.
DTC B0361 Left Actuator Feedback Short to GND
The HVAC Control Assembly receives a LH electric actuator position signal from the LH electric actuator. The LH electric actuator position sensor is a potentiometer that is tied to a 5 volt reference source through CKT 1791 and to ground through CKT 1798, both from the HVAC Control Assembly. The variable output from the potentiometer feeds back a position signal through CKT 733 to a pull-up resistor located in the HVAC Control Assembly. This signal is used to determine the necessary drive signal to the LH electric actuator motor to provide the proper air mix door position. This value is stored in the Keep Alive Memory (KAM) portion of the HVAC Control Assembly.
Conditions for Setting the DTC
With the ignition in the ON position, CKT 733 is checked continuously.
CKT 733 stays at or near 0 volts.
Action Taken When the DTC Sets
The HVAC Control Assembly stores a DTC B0361 in memory.
No driver warning message will be displayed for this DTC.
Conditions for Clearing the DTC
Using the IPC clearing feature.
Using a scan tool.
A history DTC will clear after 50 consecutive ignition cycles if the conditions for the fault is no longer present.
Diagnostic Aids
If the DTC is a history or an intermittent. Try to perform the tests shown while "wiggling" wiring and connectors, this can often cause the malfunction to appear.
Visually inspect sensor connector and harness for damage, corrosion or water intrusion.
Check for adequate terminal tension, mis-routed harness, rubbed through wire insulation, and broken wire inside insulation.
Install a scan tool to the diagnostic link connector. Turn the ignition switch to the ON position. Select the OUTPUT CONTROL screen in HVAC special functions. Use the MISCELLANEOUS TEST screen to manually drive the LH electric actuator with the scan tool from fully open to fully closed. Monitor the LH MIX MTR POSITION FEEDBACK with the scan tool when this is done. A normal position feedback signal should range between 0-255 counts as the electric actuator is being moved.
Test Description
The numbers below refer to the step numbers on the diagnostic table:
This test checks for the 5 volt reference signal being sent from the HVAC Control Assembly along CKT 1791.
This step is determining if a short to battery voltage exists on CKT 1791.
This step is checking for the 5 volt reference signal being sent from the HVAC Control Assembly along CKT 733.
This step is checking for a short to ground in CKT 733.
This step will repair a short to ground in CKT 733.
Replace the HVAC Control Assembly.
This test checks for a short to ground in CKT 1791.
Repair the short to ground in CKT 1791.
This step is checking for continuity of CKT 1798.
Repair open in CKT 1798.
This step will replace the LH electric actuator.
Erase all DTCs and recheck for repair verification.
This step is determining if a short to battery voltage exists on CKT 1791 with the HVAC control head and the LH electric actuator disconnected.
Checks for an open in CKT 1791.
Repair the open in CKT 1791.
Repair the short to battery voltage in CKT 1791.
And now the B0441
DTC B0441 Left Actuator Out of Range
Circuit Description
When the HVAC Control Assembly is first connected to power (or the battery connection is established), the system will perform an initialization routine lasting approximately 60 seconds. During this routine, both RH and LH electric actuators will cycle full travel in both directions learning the end positions. Position feedback readings are sent back to the HVAC Control Assembly and compared to a range of acceptable end readings. If during initialization the position feedback readings are not within the acceptable range, a diagnostic code will be set. If the position feedback readings reach values of 0-5 counts or 250-255 counts, the HVAC Control Assembly will then interpret the reading as a "feedback-short" or "feedback-open" condition respectively. IMPORTANT: Feedback-short or feedback-open conditions can occur due to electric actuators being initialized while not being attached to the HVAC module case.
A damaged or bound up temperature door mechanism.
Improper alignment of the temperature door after electric actuator replacement.
The electric actuator has not been initialized after replacement.
During initialization, the position feedback reading is not within an acceptable range.
The HVAC Control Assembly stores a DTC B0441 in memory.
Using a scan tool.
Diagnostic Aids
Test Description
Repair the open or high resistance in CKT 1798.
This step is determining if a short to battery voltage exists on CKT 1791 with the HVAC Control Assembly and the LH electric actuator.
Repair an open in CKT 1791.
Repair a short to battery voltage in CKT 1791.
There is a TSB listed for these 2 codes. It came out May 2003. For some reason I cannot pull it up. It is TSB pi01069.
Logan Diagnostic
http://www.airbagcrash.com
To Codes HELP!
