How do I go about replacing wheel studs???
Old Jun 29, 2004 | 05:35 PM
oufan2929's Avatar
oufan2929
Default How do I go about replacing wheel studs???
After many times of changing out DR's for my street tires, I've worn out a couple of studs. Does anyone have some instruction for me as to what would be the best route to go to change them out. Thanks a lot! --Andy
Old Jun 29, 2004 | 05:58 PM
HalfMoon's Avatar
HalfMoon
Default Re: How do I go about replacing wheel studs??? (oufan2929)
checkout http://www.ls1howto.com and the article about installing the brakes on a C5. that will show you. Basically it involves the use of the precision tool called a "Hammer".
[Modified by Tony_C5_04, 2:58 PM 6/29/2004]
Old Jun 29, 2004 | 07:14 PM
oufan2929's Avatar
oufan2929
Default Re: How do I go about replacing wheel studs??? (Tony_C5_04)
Thanks Tony...I always forget about ls1howto.com. That's a great site!!
Old Jun 29, 2004 | 08:18 PM
oufan2929's Avatar
oufan2929
where are there the how to's to do it in the rear rotors. ls1howto only had the fronts
Old Jun 29, 2004 | 08:24 PM
Shylor's Avatar
Shylor
I believe the rears are basically the same procedure.
Old Jun 29, 2004 | 09:32 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Fronts are easy... rears are tough... LG motorsports says to drill a hole where the stud can be hammered out and replaced easily
VR
Old Jun 29, 2004 | 09:34 PM
kumar75150's Avatar
kumar75150
Default Re: How do I go about replacing wheel studs??? (vetterdstr)
one of my wheel studs actually broke off
I need to get that taken care of.
Old Jun 29, 2004 | 10:36 PM
VetteTech81's Avatar
VetteTech81
I wonder why you guys are having problems with worn out and broken studs.. just curious.. are you using a torq stick with an impact or hand torqing them with a torq wrench or just by feel? just curious..
-Rick
Old Jun 29, 2004 | 11:32 PM
oufan2929's Avatar
oufan2929
Default Re: How do I go about replacing wheel studs??? (VetteTech81)
After lots of abuse w/changing out drag radials w/street tires and wearing out lug nuts, the studs just gut worn out as well. I've got two that have snapped on me today, loads of fun let me tell ya!!! Yea, it's time to invest in a snap-on torque wrench...Dang that could buy me 10 bottles of N20!
Old Jun 30, 2004 | 06:38 AM
AU N EGL's Avatar
AU N EGL
I replaced mine as well. I put in longer studs to accomidate a 1/2 spacer on the rear I use with my track wheels. I also put in hardened studs.
I got the studs from summitracing.com
To How do I go about replacing wheel studs???
