Situation has arrived...
Old Jun 30, 2004 | 02:05 AM
ilcorvettegiallo's Avatar
ilcorvettegiallo
Default Situation has arrived...
I took my car to the dealer for clutch install, ac check/repair, and an alignment. I have headers, big cam, heads, the works done to the car...anyways, when I went to get the car and start it, it threw a million codes.
Did a few start cycles, and all the codes went away but one code keeps coming back. It is the P0300 code, which is a misfire code. The car was tuned and running excellent before it ever went in there.
I never had the misfire code before I went there, but now I do. I am wondering what could have been done to cause this.....Maybe a leaky header since they did have to come off for the clutch install....I dont know....
It also only really throws this code at an idle or just crusing around at low speed and rpms.
Any ideas from anyone?
Thanks again in advanced!
Old Jun 30, 2004 | 02:11 AM
BigBlue's Avatar
BigBlue
Default Re: Situation has arrived... (ilcorvettegiallo)
I'd check the plugs and wires.
Old Jun 30, 2004 | 04:07 AM
ilcorvettegiallo
Default Re: Situation has arrived... (BigBlue)
I took the wires off and snapped them back on, and nothing.
Old Jun 30, 2004 | 08:37 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Check the ground wire, back of drivers cylinder head. Check the coil pack connectors. Have another set of spark plug wires to try in the mean time?
Old Jun 30, 2004 | 10:07 AM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
Default Re: Situation has arrived... (JoeyG)
With almost any cam you will get P0300. Maybe they did something with the pcm? Have it LS1 edited out.
Old Jun 30, 2004 | 10:32 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You need to let the person who did the clutch install fix this because there is no doubt in my mind they caused it, the first thing that needs to happen is to hook up a scanner and find out which cylinder or cylinders are misfiring.
Old Jun 30, 2004 | 10:52 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Situation has arrived... (NV MY C5)
particullarly if you have an over lapping cam the code must be turned off with ls1edit--I just find it odd that it started after a clutch install and you had no probs before--did they touch the pcm for any reason--they disconnected the battery for the install i'm sure, did booting the PCM back up after the reconnect cause it to recognize the code---if you don't have a cam then they did something--
Old Jun 30, 2004 | 11:45 AM
VetteTech81's Avatar
VetteTech81
Default Re: Situation has arrived... (NEPTUNEBILL)
How do you know that? maybe it is there fault maybe it's not.. you need to find out what is causing the problem first.. could be a stuck injector.. an ignition coil that just went bad.. there are many possibilities as to why a cyclender is missfireing.. maybe there is a fuel deliver issue of some sort causing a random missfire.. find the facts then point fingers.. most techs try their best to solve a customers complaint or issue.. not cause them.. there are enough problems out there that we do not need to create more to profit from.. just my .02 could be there fault could not..
-Rick
Old Jun 30, 2004 | 11:47 AM
jrose7004's Avatar
jrose7004
Dealers!
Old Jun 30, 2004 | 12:20 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: Situation has arrived... (jrose7004)
After I did heads/cam, everything was fine at first, then I started getting misfires. Turns out my plug wires were too close to the headers and even though they did not appear to be damaged, they were toast on 2 cylinders. Replaced the MSD wires with stock wires/stock heat shields and everything has been fine for a year.
Old Jun 30, 2004 | 12:27 PM
mwittkopf's Avatar
mwittkopf
Default Re: Situation has arrived... (Jeff Jeff)
Did you have any aftermarket programming in the car with the cam? Most of the time, tuners de-sensitize the knock parameters at idle for a big cam. If the dealer flashed the computer with a new update as a "courtesy" for you, you may have completely stock programming in there again.
Mike
Old Jun 30, 2004 | 03:12 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Default Re: Situation has arrived... (mike@xtreme)
Mike
Ahh shoot, you beat me to it!!
I would definitely check to see if they flashed the PCM as a result of a recall, i.e. CL, etc. I hope (for your sake) they did not, unless you can restore it. Good luck.
Old Jun 30, 2004 | 03:43 PM
Face's Avatar
Face
Default Re: Situation has arrived... (Dan_the_C5_Man)
Mike
Any big cam will cause that code, most tuners will delete it for you without telling you.
Old Jun 30, 2004 | 06:45 PM
ilcorvettegiallo
Default Re: Situation has arrived... (Face)
I went back today and they said 3 of the cylinders were misfiring every once in a great while. They said 2 of the spark plugs (NGKs) were fouled out, and that 1 of the spark plugs wires were not sealing right. I find it kind of weird that it never did it before, but now it is.
I talked with Lou at LGM, and he said if they flashed the pcm to stock, the car would not be running. I have the G5X-3 cam on a 110 lsa, along with the FAST 90 mm intake and the LGM 90 mm TB.
The car has less than 10k miles on it, I can not see how the wires are not sealing right/disfunctional.
Some of the wire boots do touch the headers, but I can not seem to keep them from touching.
I wish I could get the car back to LGM in Texas, because the car is still not idling right from the latest tune in Detroit, MI.
[Modified by ilcorvettegiallo, 5:46 PM 6/30/2004]
Old Jun 30, 2004 | 06:53 PM
Face's Avatar
Face
You need these: http://www.designengineering.com/pro...sp?m=sp&pid=22
They're a must if you have headers.
Old Jun 30, 2004 | 07:14 PM
ilcorvettegiallo
Those are on there already. The actual black boot itself that connects to the plug touches the header.
To Situation has arrived...
