Warning lights/messages
Old Jul 5, 2004 | 11:56 PM
kirt's Avatar
kirt
Cruising
Default Warning lights/messages
I have a 99 coupe and I was driving about a week ago and my right tire hit a average size pot hole. My service ABS and service active handling and traction control message flashed on my message screen and the lights lit up on my dash cluster. My brakes felt fine and I cant tell any difference on the traction or active handling systems. I parked the car and the next day the warnings were gone and stayed gone for about a week. Tonight I hit a very small bump in the road on the same side "right side" and the warnigs are back agian. Does anybody know what I can do to fix this problem? Help!
Kirt
Old Jul 6, 2004 | 03:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Warning lights/messages (kirt)
Counds like you have a loose connector/plug on that wheel. Recommend you check the wiring and connectors and let us know what you find
BC
Old Jul 6, 2004 | 04:42 PM
jjcslynn's Avatar
jjcslynn
Default Re: Warning lights/messages (Bill Curlee)
I had the same thing, turned out to be a bad hub/bearing. I guess the internal sensor was intermittent. Would set off the code cold with hard bump, or hot small bump.
To Warning lights/messages
