Are the 2001 and newer MAF bigger then the 1997-2000 MAF?
Yes, they are.
The 01+ MAF are the same for the LS1 and LS6, however. the LS1 versions have a metal screen on the inlet side, the LS6 version does not. This is the only difference I believe.
I also do not know how easy or difficult it is to upgrade to the late model MAF sensor, as I believe the late model also incorporates the IAT sensor in it, where the 2000 and older models had a seperate IAT sensor? I'm not really sure, but it would seem if this is the case, some wiring changes would be needed and it might not be a simple plug and play upgrade.
I'm sure someone has done this upgrade and can tell you what's all involved.
My wife has a '98 C5 and I have an '02 Z06. I'm at work now, but I'll take a look at the differences when I get home. I'll post the answer in ~2 hours or so.
