Battery Fault Code #1&2
I just checked for DIC Codes on my '00 FRC. There are four: AO2282 2284 A12283 2285. These are listed as Right & Left Door Control Module Battery Fault #1 & #2. I checked the archives and found that there are a number of possibilities for these codes being thrown, most having to do with charging systems faults. I'm wondering if having a battery go dead over the winter would cause these codes to be thrown.
The actual code should start with the letter B P C or U followed by 4 numbers and an H or HC
For instance B2282H means that this code is in history and not a current problem. B2282HC means it is in history but also a current problem.
All codes of this type will be set if the battery voltage has gone below 8.5 volts or over 16.3.
Let me know if you have any codes that have the C at the end and I will give you more details.
Have your battery checked out at a good shop. Autozone, Pepboys and Advance will do it for free!
