I finally wired my Escort 8500 into my electrochromatic mirror on my Z. I found the 2 wires that turn on/off with the ignition, and now I am very happy!
I took pics to help those of you thinking about doing this
Are you positive on the wiring as it looks like you have a black wire on the mirror side labeled = 12v+ usually black is always ground while you have the red showing to be ground ???
The wires you want are orange and brown. They look black and red in the picture, but there are 2 other wires that are black and red. The brown is positive and the orange is negative. Sounds weird, but if I had it mixed up, my detector would not work. I actually took the smart plug apart to determine what the detector needed.
This connection is switched. I had to turn the key on to get the meter to register the voltage.
i only have the map lites on my mirror will that work?
don
Yes. IIRC, there are four wires on the standard mirror, two orange, brown and black. Brown is switched 12V, and black is ground. One orange wire is always hot, and one is hot with the door circuit.
It's been awhile since I did the check, so use a voltmeter to check for sure!
Particularly important is the note that the hot wire is door switched, meaning it is off with the door open. I didn't know this and sent back a perfectly good phone cord because I could not activate the V-1 with the door open!! Best,
I had to use the black and one of the orange wires.
Ifyou have the autocromatic mirror it has a seven prong plug the second orange wire in from the end is the ground the brown wire on the oppisite end is your swiched hot
