Reving in neutral
Old Jul 10, 2004 | 03:26 PM
ilcorvettegiallo's Avatar
ilcorvettegiallo
Default Reving in neutral
What are the negative effects of reving your C5 in neutral to the redline and back a few times. Will it actually do some serious harm, or is it alright to do once in a while. Say this C5 has a upgraded valvetrain.
Old Jul 10, 2004 | 03:55 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
bent pushrod ?
why hit redline ?
Old Jul 10, 2004 | 05:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have reved it to around 4k but why would you want to go to red line. I go there lot under load but why would you want to do it in nuteral?
BC
Old Jul 10, 2004 | 08:50 PM
ilcorvettegiallo
There was a muffler rapping contest in a show here, so I was curious as to how bad it could have been.
I figure it has a limiter, so it would hit that before damage could occur.
Old Jul 10, 2004 | 09:25 PM
Donovan 572's Avatar
Donovan 572
It's very hard on the rods. That's why many drag racers go to neutral after the finish line rather than let the motor coast down in gear. High RPMs are harder on a motor with no load. Some motorcycle owners manuals will even give you a max RPM for no load and it's much lower than the redline.
Old Jul 10, 2004 | 09:34 PM
Dope's Avatar
Dope
Resident moron
FYI, it's supposed to be hard on rods and whatever, but have you ever heard of anyone blowing up a motor by revving in neutral? Assuming of course that you have a rev limiter.
I haven't.
Having said that, I rev it up whenever I feel like it in neutral. I just don't do it when it's cold.
Dope
Old Jul 10, 2004 | 09:41 PM
Donovan 572
I haven't.
I have!
I saw a motor grenade on the starting line while reving high with no load. Chunks flew everywhere. A piece of a rod even hit the starter on the arm.
It was a manual trans car and he had been hitting the rev limiter while waiting for the light. It let go just before he dumped the clutch.
Old Jul 10, 2004 | 09:49 PM
Donovan 572
I haven't.
I have!
Old Jul 10, 2004 | 10:35 PM
ilcorvettegiallo
Well after a little hard spirited driving, the car sat over night, and there was oil all over the floor of the garage. I moved the car to a different spot, put some plastic down, and no more has dripped since. There was about 30-40 drops on the ground.
Is it possible that oil could blow out somewhere if the motor sees to much rpm, and just drip down for a while?
Old Jul 10, 2004 | 10:56 PM
Dope's Avatar
Dope
Resident moron
Maybe if the motor was overfilled, but otherwise - no. Is the filter tightened down? Drain plug?
Dope
Old Jul 10, 2004 | 11:17 PM
ilcorvettegiallo
Yeah, I got an oil change that same day. The plug and filter are both tightened well. It doesnt seem to be dripping from that location....kind of seems to be coming from up in the motor area by the underdrive pulley or something.
Old Jul 11, 2004 | 01:47 AM
Dope's Avatar
Dope
Resident moron
If you had just gotten an oil change, I bet they spilled it while filling up. The oil slowly dripped down the side of the engine and left drops all over the floor.
I've done it myself.
Dope
Old Jul 11, 2004 | 02:35 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
dope do you realize how easy it is to bend a pushrod on an ls1 ?
Old Jul 11, 2004 | 02:32 PM
ilcorvettegiallo
I took it to my friends work, a quick lube place, but I did all the oil pouring and everything.
I am just hoping no seals blew when I was doing the spirited driving. I will take it to a dealer and see if they can tell where its coming from.
Old Jul 11, 2004 | 04:53 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
spirited driving or reving in neutral ??
Old Jul 11, 2004 | 09:38 PM
H82GOSLW's Avatar
H82GOSLW
I'm with Dope, it's probably oil that was spilled during the oil change. After almost every oil change I get on any of my vehicles, there seems to be a spot of oil on the garage floor the next morning, then nothing after that. If you put plastic on the floor and didn't see anything, I wouldn't bother bringing it to the dealer for a check. If anything, they'll make up some sort of malady and tell you that you need have your muffler bearing or 710 filler replaced.
Old Jul 11, 2004 | 10:33 PM
ilcorvettegiallo
There was oil on the floor after the driving. I spilled nothing from the oil change, but I noticed there was a drip forming from the drain plug before I loosend it.
Old Jul 12, 2004 | 06:12 PM
ilcorvettegiallo
Went for a drive, parked the car for 20 minutes, and not one drop. Some crazy stuff.
Old Jul 12, 2004 | 07:06 PM
Patches's Avatar
Patches
Originally Posted by Donovan 572
I have!
A forum member did that once here not long ago. Was revving it hard in neutral for his buddies and, pow! That's all she wrote.
To Reving in neutral
