Battery starting to die?
Old Jul 10, 2004 | 07:51 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Default Battery starting to die?
I'd heard so many horror stories about Delco AGM batteries dying with no symptoms that I installed an Optima Yellow Top about 6 or 7 months ago. The yellow top had been running fine until the past day or two. Now it seems as if it is struggling a bit to turn the engine over when cranking. And twice today when I cranked it, it went back to default settings on the DIC and HUD, showing the odometer and coolant temp. Once it is cranked, it is good to go, and gets me fine to my destination. I think that the alternator is fine, but somehow the battery is starting to die. Are these the correct symptoms of a battery going bad? I have NOT seen any DIC message of "charging system fault" or others; just the dic resets itself after cranking, as if it lost power.
Thanks!
Edit: I forgot to mention that when monitoring the voltage just before cranking, it is around 11.2 V. Once it is running, it is around 13.8-14.0 V.
Old Jul 10, 2004 | 08:01 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
any headlight dimming or actual power loss symptoms?
Or is it just hard on the crank? That could be wires? plugs? ignition? fuel pump?
Maybe try to push the gas pedal first to get gas in the lines and then crank it over turn the key to acc on position the pump will be on then finish the key turn?
Just some ideas to help troubleshoot. If your battery has a voltage prob then id say your dic would show the low voltage or you can easily have your alternator or battery tested. Is something possibly draining the battery while it is parked?
Sounds like a gremlin hunt to me
Old Jul 10, 2004 | 08:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GTC
The OPTMA yellow top has a warrenty!! I would take the car back to the place that you purchased the battery and let them check out the charging system and the battery. If the battery is bad they should replace it!
PLEASE LET US KNOW HOW THIS PANS OUT!
BC
Old Jul 10, 2004 | 11:16 PM
Richin Chicago's Avatar
Richin Chicago
Thanks!
Should be 12.6 before cranking.
The fact that the DIC and HUD went back to default meant that you are definitely at very low voltage when the car is starting. In fact you are only a few 10ths of a volt away from the car not starting. Because you are still showing 14 volts when the car is running suggests to me that the battery is the problem. Any chance you are taking such short trips that the battery just isn't recovering? You might try an overnight charge and see if you are back to normal. The Yellow is supposed to be able to take a lot of deep discharges. If that doesn't do it you might want to get another battery.
The only other thing I can think of is to look for corrosion on all of the connections but I think that may be remote.
Old Jul 11, 2004 | 01:38 AM
Mel 2001's Avatar
Mel 2001
Old Jul 11, 2004 | 05:30 AM
06C6FVR's Avatar
06C6FVR
bad battery, get it checked
Old Jul 11, 2004 | 06:20 PM
2000droptop's Avatar
2000droptop
St. Jude Donor '07
Old Jul 11, 2004 | 06:45 PM
wwashing's Avatar
wwashing
Maybe you haven't been running enough to keep the charge up. Try charging it.
Old Jul 11, 2004 | 08:31 PM
GTC's Avatar
GTC
Cruise-In V Veteran
Thanks for the tips. Most of my recent trips have been of the 10 minute to-the-office variety this week. I'll take the scenic way a couple of times, and see if she recharges and holds a charge better. The times that I've cranked her up today, she hasn't lost so much power that the dic/hud/clock reset, but it still feels like a struggle to turn the engine over the first time. If that doesn't work, I'll get the battery checked.
Old Oct 2, 2004 | 06:26 PM
donnyonee's Avatar
donnyonee
yelllow or red?
wheres the best place to buy? how much?
don
Old Oct 2, 2004 | 06:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Don
I got mine at Autozone for just over $100 bucks. They had a box full of adapters and plastic brackets next to the battery rack. Guess what? It contained the correct hold down brackets for for my Z and about any other car that you wanted to put the battery in! I just took the one that fit my car. After I dropped the battery in, I found out that I purchased the red top that doesnt even need the adapter
Old Oct 2, 2004 | 07:01 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by Bill Curlee
...... After I dropped the battery in, I found out that I purchased the red top that doesnt even need the adapter
Bill: There are two different red-tops. I bought the 34/78 which does need the small "U-shaped" holdown adapter. Did you buy the 35/75 by any chance?
Robert
Old Oct 2, 2004 | 07:02 PM
Cole's Avatar
Cole
It could be the battery, BUT.... Check the connections. An intermittent ground problem does strange things on the 'vette.
Regards,
Cole
Old Oct 2, 2004 | 08:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Robert
My car is at the Dealers getting some warrenty items fixed. When I get it back i will see which model Red top is in there!
BC
To Battery starting to die?
