Air Conditioning question...
Old Jul 14, 2004 | 06:16 PM
movinlow's Avatar
movinlow
Default Air Conditioning question...
I tried doing a search, unless I did something wrong I can't find anything. I have a 98 coupe with almost 75,000 miles on it and the AC is not blowing as cold as it use to. I have the passenger control as well and if feels like it is blowing cooler then the driver side. Any thoughts would be great. Thanks.
Old Jul 15, 2004 | 03:10 PM
SilvaDragon's Avatar
SilvaDragon
Default Easy to check
Go to your local auto parts store and get an R134a pressure gauge.
(less than $20) This will tell you if your system is down on refrigerant.
If so, you may be only $8 more away from a full system...
Old Jul 15, 2004 | 03:34 PM
wrustywrench's Avatar
wrustywrench
dont know much about this , but I have seen posts about a fuse and resetting the internal doors that direct the air,, might see if someone can chime on on theis,, but I bet yo need to top off the 134, easy to do,,,
Old Jul 15, 2004 | 05:08 PM
movinlow's Avatar
movinlow
thanks, picked some up today, gonna try it...
Old Aug 27, 2004 | 05:20 PM
speedy-vet's Avatar
speedy-vet
St. Jude Donor '06-'07-'08
Time to switch to C6!
Old Sep 1, 2004 | 10:03 PM
99ragtop's Avatar
99ragtop
try the HVAC fuses it worked on my 99 Vert
Old Sep 1, 2004 | 10:46 PM
movinlow's Avatar
movinlow
They did a full recharge and it seems to be working fine, hopefully there isn't a small leak. They put some die in there and he told me to come back in a couple weeks and he would check to see if it is leaking.
To Air Conditioning question...
